Oil like drips on RX350 '13 after sitting 12 hours
I have a '13 350 F sport with AWD that has only 1k on the odo. It sat for the last week and when I pulled it out of the garage yesterday I noticed a very small puddle of liquid that was oily. I wiped it up with a paper towel and it was slightly yellow like oil or power steering fluid. Didn't have a smell because there wasn't much and I see it seems to have originated from just around the oil drainage pan but up higher than the bolt. I can't get any further to see where it is specifically. Could this just be the seals settling in and a little fluid leak happens and then disappears.
The car sat overnight and there was a puddle smaller than a dime where a couple more drops had fallen. With the condenser on the AC sweating I didn't know if this was just water blowing back into other components and then mixing or just a little power steering fluid. All levels on the car are good and it seems when the engine is hot the seals are tight. The right front drive shaft has a little darker spot on it as a few other components do as well. Could just be grime though too.
Trying to avoid taking it to the dealer as they always damage something as of late and since the engine is breaking in, if this was a result of a different engine oil that was thinner for the break in process.
I'd definitely keep a watch on it. You're engine oil when new or 'fresh' is hard to see on the dip stick. And it's the same new as later. 0w20w synthetic. These cars do not have a break in oil.
Put a paper tower under it overnight. Then check if it burns. If it's flammable - it is oil based, if not - water based*
It is possible that if the oil was topped-off during the prep process that some of it spilled and is now making its way down. I had that happen to me a couple times in my IS when I changed my own oil and poured the oil too fast.
Although I don't like taking my vehicles to the dealer as well, it may be prudent to do so just so there's a record of a problem. So if your engine seizes due to oil or other liquid running low, you would not be responsible.
* I am not responsible for any damage done during this test
I'm going to keep an eye, but this is not even half a teaspoons worth of fluid. And in the first 2 months I never had this happen. Only since we've had two cars. And this one is parked over. Also hadn't used the A/C much till lately, so I'm not worried about fluid loss yet, but what it could become and that it's even happening.
Had a similar problem with our RX. Turned out to be grease from the axle boot getting on the engine and then dripping down. They replaced the boot and haven't had any more leaks.
Thanks for letting me know though. I had traced the drips to this area. So I'm at two days without anymore drops. So very random. But I also had a VW sedan that the first spring I had this wax like substance drip out of the bottoms of the doors onto the running boards. Turned out it was normal too. Never had any more drips after the season ended.
OP, I've never had a single oil drip from any of my Lexus since 1995. As mac12 says, if the problem reoccurs and you have not dinked with anything under the hood, don't even ask the question here on the boards, just take it in for service. That's what warranty service is all about.
Don't understand your concern with having the dealer take a look. I've had a transmission changed on an LS 430 ,(they recalled 13.000 of them), valve springs replaced on an LS 460 (model wide recall), air conditioner condenser replaced for noise (LS 430), leather driver's seat replaced (LS 430), all rugs replaced on an LS 430. Never had a problem with dealer maintenance and all covered under warranty. Lexus sent me a $200 gift gas credit card for the inconvenience of the transmission change out.
The issue is I have had the dealer damage both of my new cars on their first and only trip in for service. Door ding and the other the skirt got scraped by the tech not knowing how to use a lift. So if its just a little excess grease and it never does it again, I'm more than happy to just wait and see. Besides, next closest dealer is an hour away. So if it's not critical, that was why I posted. I'm not as fortunate as others on here who have a competent service department. Mine is overly busy with little room to store the cars and techs that don't have detail oriented mindsets without going into too much detail.
