HUD not coming on.
Old 07-12-12, 02:06 PM
daisymay
daisymay's Avatar
Default HUD not coming on.
Would anyone have an idea of why the Head up display in my RX 450 would not come?
Old 07-12-12, 03:09 PM
kitlz
No, I don't play soccer!
kitlz's Avatar
Welcome to CL daisymay. Have you tried pressing the HUD button to the right of the steering wheel? It also switches it over to km so you may need to press it more than once.
Old 07-12-12, 03:11 PM
NoLFA4U
NoLFA4U's Avatar
There is also a switch that adjusts the level at which the HUD can be seen.
We had the same issue, and it turned out that it had been adjusted to where only a Hobbit could see it.
Old 07-12-12, 03:39 PM
BertL
BertL's Avatar
...or it's set too dim. On my 2013 there are three switches to the right of the steering wheel below the dash panel indicators in front of your right knee. The left one turns HUD on/off and as Anitia suggested will toggle betweem mph/km (it's a 3-way), the center one is brightness/contrast, and the third on the right raises/lowers the display as NoLFA4U suggests. Check the first two on the left of that set... You need the HUD on and super bright to begin with, then adjust from there. If that does not work, time for Lexus Service. Let us know! ...and congrats on your RX!
Old 07-12-12, 05:39 PM
RXSF
RXSF's Avatar
all possible quick check solutions have been covered by our excellent members above!
Old 07-16-12, 11:55 AM
daisymay
daisymay's Avatar
Thank you all. It was turned down. I turned it up without any problems. Thanks
tlynch41
RX - 4th Gen (2016-2022)
04-29-19 12:06 PM
Steve19067
ES - 6th Gen (2013-2018)
10-04-18 03:19 PM
Onyx00
RX - 3rd Gen (2010-2015)
15
01-28-17 09:11 AM
winsalem
11-14-12 12:07 PM
Mike216
01-12-09 07:30 PM
Quick Reply: HUD not coming on.
