Nitrogen and Valve Stems
Old 03-14-12, 07:45 AM
GRPFAN
GRPFAN's Avatar
Default Nitrogen and Valve Stems
When my 2012 RX was delivered, on the contact I was charged $50.00 to add nitrogen in all four tires.
I hear that when nitrogen in present the valve stems are a different color............
How important is this and should I mention this to my dealer @ my 5,000 mile check.
Cheers!
Old 03-14-12, 08:42 AM
User 41924
User 41924's Avatar
Nope. If you look at your valve stems, you will see green somewhere. Sometimes the caps are green, but these are sometimes removed by people that think they need them more than you do. My valve stems have a green ring on them below the cap. The green tells everyone the tires have been inflated with nitrogen.
On a side note, it is interesting to follow the arguements regarding the value of using nitrogen to inflate tires. Personally, I kinda like nitrogen in the tires, but I'm not really convinced it's worth the $50 they charge to put it there. There are LOTS of differing opinions!
Old 03-14-12, 08:54 AM
GRPFAN
GRPFAN's Avatar
Woodrow,
Thanks for your input.
This is all new to me and I agree with your last statement
Old 03-14-12, 09:10 AM
BertL
BertL's Avatar
Interesting. I must be way behind the times having never heard of nitrogen in normal street tires vs. the space shuttle, airplanes and such. For anyone else wondering what some of the pros/cons are, a google search does wonders, but here is one general article to get you started.
Old 03-14-12, 10:14 AM
TomT127
TomT127's Avatar
I would question that $50 charge. That's ridiculous and not just because of the nitrogen vs regular air controversy.
1. Nitrogen is CHEAP. That nitrogen cost the dealer probably less than a nickel.
2. Even at inflated dealer labor rates it should have taken no more then 5 minutes to fill all the tires.
3. If you did not ask for this service then I don't know why your paying for it.
Sorry but I think they ripped you off big time.
Old 03-14-12, 10:22 AM
Lexmex
Super Moderator
Lexmex's Avatar
Where I am at it ranges $25 to $30 for all 4 tires and I can get topped of for free (but I usually give the person doing it like a $5 tip).
$50 is robbery.
Old 03-14-12, 01:16 PM
cafpaf
cafpaf's Avatar
Certainly not worth it in my opinion. After 26 years in the Air Force and retiring as Chief of Maintenance for a fighter wing, I fully understand the use of nitrogen in aircraft tires, but for a car I just don't see it. Further to charge $50 is just insane. If you really must have it, Costco will do it at no charge with new tires and will top them off whenever necessary at no charge. Just plain old air for me.
Old 03-14-12, 03:47 PM
happy1977
happy1977's Avatar
If you question them about the $50 charge, they'll respond to you with this: "You're driving a Lexus, sir."
Old 03-14-12, 06:00 PM
JellyBean
JellyBean's Avatar
or "Expensive? that's only X cents for each of the Y miles you've driven"
Old 03-14-12, 06:06 PM
hypervish
hypervish's Avatar
My tires are nitrogen filled, and have a regular valve stem. No special cap.
If I need to top off a tire, I just use regular air.
Old 03-14-12, 08:46 PM
Barrington
Barrington's Avatar
The Hyundai dealer that I was working at would take the car into the shop and install pretty blue aluminum caps when they charged the customer for the nitrogen. Oh wait, the fancy machine did not work because the owner of the dealership did not want to spend money to repair it. Smoke & Mirrors, Abra-Ca-Dabra......
Old 03-15-12, 06:20 AM
User 41924
User 41924's Avatar
"Regular" air is 78% nitrogen .....
Also, How do you get all of the "regular" out of the tire before putting in the nitrogen? Won't you always have SOME oxygen in the tires?
Old 03-15-12, 06:23 AM
Lexmex
Super Moderator
Lexmex's Avatar
You don't. The nitrogen ratio just kind of improves with topping off over time.
Old 03-15-12, 08:07 AM
LexBob2
LexBob2's Avatar
My car was delivered with nitrogen at no charge. I wouldn't pay extra for it but have noticed over the past two years the tire pressures don't fluctuate much at all with temperature changes, and I check them regularly. It is convenient from that standpoint.
Old 03-15-12, 01:24 PM
UCSB
UCSB's Avatar
I thought my 450h was delivered with nitrogen, but there is no indication of this on the valve stems or caps. So now I just don't know the status. One nice thing on the 450h is that it shows the tire pressure in each tire in the information display area. That addresses many of the arguments for using nitrogen because you know your actual tire pressures.
Quick Reply: Nitrogen and Valve Stems
