Shift lever squeeks
Old 08-18-11, 01:41 PM
krypttic
krypttic's Avatar
Default Shift lever squeeks
When I move the shift lever up (from Drive to Park or Drive to Reverse), it squeaks. Moving the other way doesn't make a noise. The noise is clearly coming from right below the lever. Can this thing be lubricated somehow?
Old 08-18-11, 03:54 PM
RXSF
RXSF's Avatar
I know it can be lubricated because part of the lower end of my shifter by the gate, I still see white lube residue.
Old 08-19-11, 07:17 PM
EMSLEXUSRX
EMSLEXUSRX's Avatar
Mine started doing the exact same thing about two months ago. I've had my RX just over a year. It's either squeaking or rubbing. I'm due for a tire rotation, so I'm planning on having the dealership address it when I go in.
Old 08-19-11, 10:04 PM
krypttic
krypttic's Avatar
Let me know what they say, please.
Old 08-19-11, 10:44 PM
data2009
data2009's Avatar
Same problem. Last month, I had a side mirror fixed, together with a moaning/grinding steering wheel column, and asked the dealer to fix. Mechanic who looked at it said they need to replace the part (not sure they meant the whole shift lever, or some gears inside - lubricating it did not help). They had to place the order on the part, so I will have this done when I'm up for 30k service, a few months away.
Old 09-30-11, 11:59 PM
krypttic
krypttic's Avatar
Any definitive answer on what this is yet?
Old 10-03-11, 08:01 PM
EMSLEXUSRX
EMSLEXUSRX's Avatar
Well, when I took it in for the tire rotation service, I told them about the shift lever squeaking and they sprayed it with silicone, but it is still squeaking. So I guess when the next service is due, I will address it again with my service guy. By the way, it only happens when shifting from drive to park, not the other way around. Don't know if that's the way it's going on you guys' RX's.
Old 10-03-11, 09:58 PM
krypttic
krypttic's Avatar
Same here. If you look at my original post, I stated that only moving the lever up makes the noise.
Old 10-13-18, 10:10 PM
Jus
Jus's Avatar
Hi, my brother has a 2015 RX, and it is also making squeaking sounds when shifting. Was there an actual resolution to this issue?
Old 10-15-18, 12:25 PM
m5rahul
m5rahul's Avatar
I experienced this as well on my '15 RX ( ~ 35K miles ) as the temps drastically dropped last week ( along with the damn TPMS light ). However, it seems to have gone today ( 10/15/18, Monday ) as ambient temps went up a bit.
Old 10-16-18, 10:36 PM
JLSC
JLSC's Avatar
My 2012 RX 350 shifter just started making the squeaking noise as well on an intermittent basis while shifting from Drive to Park or Reverse. When shopping for this vehicle last year I found that most of the RX 350's I test drove (about 10 of them) had squeaky shifters. A local Lexus dealer who inspected one of the RX's said that the shifter assembly would need to be replaced if I wanted to get rid of the noise since it's not a serviceable item.
Old 10-29-18, 11:27 AM
Jus
Jus's Avatar
Took it to dealer, and they say “it’s normal”. Definitely unacceptable as they just don’t care and don’t want to fix it. Will need to escalate to corporate if they don’t do anything about it. Did anyone actually have it fixed via lubricant or part replacement?
flashes23
05-20-17 01:40 AM
ChitChat
RX - 3rd Gen (2010-2015)
06-30-14 09:28 AM
trixxx519
Suspension and Brakes
05-23-11 08:08 PM
trixxx519
05-20-11 06:20 PM
brendam24
02-08-11 10:53 AM
Quick Reply: Shift lever squeeks
