Engine buzzing/whining noise at idle
2nd gear
Hello,
I just recently purchased a new 2011 Lexus RX450h.
I am now getting a pretty loud buzzing noise when the car is at idle. (especially just after starting up)
I attached a sound file. Is this normal? The dealer says it is normal because it is a Hybrid. I find that very hard to believe. It sounds like a car with a bad bearing or something.
After spending the amount of money I spent on this car I would not expect it to make noises that sound like something is seriously wrong.
Any help would be appreciated.
The noise was recorded next to the passenger side wheel well. At the end of the recording I placed the recorder near the oil pan. It seems like this noise is coming from the area near the oil pan.
Thank You,
Peter Geremia
Ps. If you have a 2011 RX450h maybe you can help me to determine if the noise is normal or not?
Thank You,
Peter Geremia
Hello,
Thank You,
Peter Geremia
Thank You,
Peter Geremia
If you get it resolved other than your dealer, go on to citisearch, yelp and the BBB websites and report it there. This dealer needs to get a hurting put on them for lack of professionalism. You will be getting a survey from Lexus on rating your experience with your dealer. GET OUT YOUR RED PEN!!!
Hello,
Thank You,
Peter Geremia
Thank You,
Peter Geremia
Peter, this noise sounds weird. I don't know if the cold weather out there makes your engine run louder. You definitely need to visit your dealer and maybe you can test-drive another 450h from their cold parking lot.
My 400h would shut off the engine and be silent after a few seconds stopped. The new 450h also does. Definitely take it back to the dealer--or if needed a different Lexus dealer.
Hello,
Thank You,
Peter Geremia
Thank You,
Peter Geremia
Not sayin you don't have a problem, but.
One thing that is very different in hybrid is the "idle". Idle in non-hybrid is the least load condition and the engine idles at around 750rpms. In hybrid there is no idle. Either the ICE is shutdown or running with the generator as a load [when the wheels are not turning]. Non moving engine RPM is much higher as compared to non-hybrid as it is under load to charge the traction batteries.
As the engine rpms are increased, there are many sources of vibration ... even a rock in the underbelly.
Salim
Salim
