New RX350 question: How to know if the 4 wheel is engaged?
I got the new RX350 (AWD) this spring; now we just had the first snow in this season. I know this 3rd gen RX350 is a basically front-drive with AWD engaged ONLY IF necessary decided by the car computer system. How do I know if AWD is engaged? Is there any indication light to tell ?
Thanks,
Thanks,
i think it starts in AWD but quickly goes to FWD if the conditions are normal. you dont know when it makes the switch. if you want "perm" AWD then press the LOCK button near the centre arm rest and it will stay in AWD mode until 40km/h, you will see a light.
Thanks for the reply. If I understand from your replies, there is no way to know the current driving mode AWD or FWD. What about the green ECO light, does it imply the AWD if it goes off ?
I guess the eco light has an indirect way of telling you whether you are using it. AWD = more gas = eco light off. However, the eco light does not take awd into account directly.
AWD comes on from a standstill to a few miles per hour, and only when you are slipping.
there's a video on how the awd works
http://www.lexus.com/models/RX/detai...fications.html
click the camera icon under drive wheels
I like watching those clips.
I test drove both the FWD and AWD and experienced much less body roll when getting on the same ramp (40mph, 360 degree complete circle type ramp) with AWD..
There is also much less under steering (almost none) w/ the AWD overall..
The system is so advanced, in fact, that it can predict your intended path around a turn and proactively provide the necessary amount of torque to help prevent front and rear wheel slip—whatever the road condition.
A LOCK switch can be used to manually select a 50:50 torque split for enhanced low-speed traction in conditions like mud or snow. Once the RX reaches 25 mph, the LOCK switch automatically disengages.
Download plug-inBroadband connection is recommended.
My memory becomes fuzzy, I don't recall if these sentences above have existed for RX10. Anyway, let's assume they do.
After driving this RX350 for almost 20 months, I still don't trust this "smart" AWD system. It seems that this system will only work once the sensors detect the "slippage". And, once the "conditions" are gone, it will "immediately" turn back to FWD. I have been having a few occassions that my car lost the tracks in the regular turns on slight wet/snowy roads, but other AWD vehicles were smoothly passing those areas.
this might be a silly question, but I just got a 2010 RX350 as a loaner and i can figure out whether its AWD or FWD.
i tried looking in the glove compartment but there is no manual and I cant seem to find my answer by searching in this forum. On the dash, an "eco" sign does come up every once in a while, does this mean the model is an AWD model?
on center console next to the cup holders, if you have 2 buttons, it is awd, if only 1 button, then it is fwd
http://autoworld.files.wordpress.com...2010-img_4.jpg
buttons are located on the very right of the pictures
I have the 450h awd and I only have one button, not two like in the pic...
