DIY LED Puddle Lamps
Old 06-03-12, 11:55 AM
  #46
cafpaf
cafpaf's Avatar
Thanks Anita. Once I muster up the courage, I will give it a try and let you know how it went. Thanks again!!!!
Old 06-03-12, 10:04 PM
  #47
Sevn86
Sevn86's Avatar
Originally Posted by VVRX
Do you need to wear gloves while installing the leds?
No not at all.
Old 06-04-12, 07:43 AM
  #48
VVRX
VVRX's Avatar
Thanks Sevn86. I didn't think so, but I had to ask. I saw a video about a complete led install and the installer was wearing gloves.
Old 06-04-12, 09:20 AM
  #49
cafpaf
cafpaf's Avatar
VVRX, please let us know what video you are referring to and tell us how to view it as well. Thanks!
Old 06-04-12, 09:32 AM
  #50
kitlz
No, I don't play soccer!
kitlz's Avatar
I didn't use gloves either. And I don't know what people are afraid of. Changing out the interior bulbs is one of the easiest mods to make to the RX. You can see the results right away. Doesn't take that long to do either. I'd give it about a 4 or 5 on a scale from 1-10. It's only that high because of the rear dome light. The puddle lamps are more difficult but for a different reason. The cracking noise it makes when removing the inner part of the mirror is not for the faint of heart.
Old 06-04-12, 09:44 AM
  #51
InRBigness
InRBigness's Avatar
you need to wear gloves when you are installing HID lights as the grease from your finger will create a hot spot on the lense and the lifespan of the bulb is greatly reduced. LED do not have that issue.
Old 06-04-12, 10:23 AM
  #52
VVRX
VVRX's Avatar
cafpaf. I believe the video was on youtube, but don't recall the exact subject matter I used to find it.
Also, I have since deleted that particular part of my search history. With that being said, I would rather follow the instructions of the contributors on this forum. You need not go any place else.
Old 06-04-12, 11:36 AM
  #53
cafpaf
cafpaf's Avatar
VVRX, thanks for the information. I will do as you advise.
Old 06-04-12, 12:40 PM
  #54
VVRX
VVRX's Avatar
cafpaf. Go to this site and click on lexus is250 2006+. The install for some of the units appears to be very
similar to the current RX. This will help some.
http://www.precisionled.com/how-to-videos.html
Old 06-04-12, 04:42 PM
  #55
svofan1
svofan1's Avatar
...I still missing the courage...I guess I will decide later on...I know...I know it is an"age" thing....<S>
Old 06-04-12, 04:56 PM
  #56
kitlz
kitlz's Avatar
No excuse. I did it and I'm a girl
Old 06-04-12, 08:17 PM
  #57
Sevn86
Sevn86's Avatar
U can do it!
Old 06-06-12, 01:52 PM
  #58
j0emama
j0emama's Avatar
I had the same hesitation pulling that mirror off afraid I was going to break something. After giving it a shot, I was amazed at actually how simple it was to remove. As long as you do it correctly not a whole lot that can go wrong. Piece of cake.
Old 09-16-12, 09:23 PM
  #59
ericsan13
ericsan13's Avatar
Use protective tape and pry from underneath after tilting mirror up
Do the same with the top after tilting down:
Remove the 4 obvious screws:
Here is how the mirror is attached. Pretty hard to mess up?
Pry open the other piece and now you can get to the light housing:
Pull it out and change the bulb:
Put it back together and viola:
Old 12-01-12, 11:44 AM
  #60
N8dagr8
N8dagr8's Avatar
slow and steady and it's a piece of cake. first thing I did after I got the car/joined this forum. It's amazing how much brighter the LEDs are.
Quick Reply: DIY LED Puddle Lamps
