rear suspension squeek
#46
I used to have rear shocks that the dealer diagnosed as a dry inner seal. They would squeak whenever I hit the slightest bump. The dealer replaced it under warranty and the new set squeaked as well but after a month of daily driving, the squeak went away. I went on a ~250mi drive yesterday and didn't even get a peep out of it. Hopefully it's gone for good *knock on wood*
#47
Squeaks from the Suspension
2011 RX450h 14,xxx miles.
It started today for the first time but I noticed a squeak/chirping coming from behind me. It sounds like the suspension when I am going over bumps or rough roads or when the road wallows. When I first had my 10,000 oil change, I noticed the same problem when I got the car back and immediately went to see my SA. He said that since the car had been on a lift, the suspension just needed some time and sure enough after a few miles of driving the sound went away.
I wonder if something is loose though my car is very low mileage. Any thoughts on the matter would be appreciated. I am going in for my 15K check up soon and would like to bring this up
#49
I had two 2010 Rx's both had the same issue in the back, both had the rear shocks, struts and trailing arm part of the back suspension replaced, on one of them the noise came back within 6 months. Got rid of both.
#50
Obviously there is some sort of design flaw for this to have soooo many complaints. My 2010 had been in for my particular squeak/chirp noise at least 6 times. Each time I tried to tell them that the noise was isolated around the shock, but they wanted to 'find' it themselves. Since they only are with the car a short time and their ears are not tuned to the noise, they had trouble locating the noise. I even showed them this forums info. Eventually, as most people have stated here, it was determined that it was the shocks. I went through at least 3 sets before I got good ones. Hopefully the bad batch has been used up by now....but I would concentrate on the shock area to start with if I were you. Mine has been quiet, in the rear, at least so far. Now I am dealing with an elusive rattle in the glove box area!!!
#51
My rear end would creak as I backed out of the driveway and this started two weeks ago. Took it in today to get a regular check up and SA came back and said they need to change out the two shock absorbers as they are leaking in the rear suspension. I don't know if y'all are experiencing something similar but they changed mine out under warranty.
#52
My 2011 has had the Shocks replaced twice now for the creaking noise. They said they were leaking. The second time around they replaced the shocks and control arms. After a couple days I noticed the creaking came back on the passenger side rear. I have 49,000 miles now, so going back before warranty runs out.
#53
ugh, funny you bring this up. I have had both trailing arms and struts replaced and I still hear the creaking noise when exiting driveways or going over speed bumps. I am out of warranty now but it seems like this problem was never resolved and I think I may have a case that this all occurred before the warranty ended
#54
Might be a little off base but tried something with my wife's car on the weekend.
Removed the jack & small parts from the styrofoam carrier under the rear cargo floor.
Sprayed the styrofoam down with a lubricant inside & out. Replaced the parts & went for a drive.
In our case, the steel jack vibrating against the styrofoam was creating quite a squeek.
Seems OK now but it's only been a few days.
Left a pair of cheap cloth gloves with the jack in case we really need to use it.
#56
#57
#58
I may get out in it this week.
Usually drive my F150 & park it in front of the garage. She parks inside & it's just plain easier to take the truck.
Guarantee the gas light will be on when I do take it !
#60
I had a rattle-squeak and found it to be two areas....I had a sunshade in the back and removed it. Most of it went away, then I noticed the center section on the back seats was not fully latched. That ended the problem.
