How Many of You Shift in Sport Mode?
Old 12-14-09, 04:02 PM
Sandi_k
Sandi_k's Avatar
Default How Many of You Shift in Sport Mode?
So, one of the big advantages of the RX350 (especially over other competitors like the Ford Edge) was its ability to have a manual shift mode.
I've been playing with it this past week, as I break the engine in (trying to avoid 2K RPM as the only band the engine operates in)...And I'm finding it fun to use the torque and engine a little more aggressively than dialed in the automatic transmission shift points.
How many of you use the manual mode? Just wonderin....
Sandi
Old 12-14-09, 04:17 PM
kitlz
No, I don't play soccer!
kitlz's Avatar
Sandi, I cant wait to play with it in my 450h. Right now I use it in my 04 to slow down on hills. It also helps in the snow. Guess you don't have to worry about that I drove manual trans cars for the first 10 years after getting my license. Needless to say I enjoy it more now.
Old 12-14-09, 06:26 PM
Sandi_k
Sandi_k's Avatar
Anita, it's one of the reasons I got the 350. After driving nothing but MT's since I was 16 (except for the occasional rental car) a strictly auto tranny was a deal breaker. (To be fair, there were many reasons why I chose the RX over the Edge, but that was definitely one of the BIG reasons).
I'm sure it plays h*ll on the hyper-mile-ing, though.
Sandi
Old 12-14-09, 07:19 PM
Cruiter
Cruiter's Avatar
Sandi
It's not hard to use and actually kind of fun but I suspect it's primary purpose is for pulling on slippery surfaces or braking on grades.
I did use our when coming down the mountain from Highlands NC and it worked perfectly. Mostly I varied it from 2nd to 3rd and back depending on the grade and speed. During that stretch I rarely used the brakes.
Old 12-14-09, 09:07 PM
LeoDLion
LeoDLion's Avatar
We were driving in the highway when I noticed that the engine seemed to be working harder. I then noticed that I got the shift lever to the left instead of to the right of the Drive which puts it in manual mode. Quite interesting.
My daily driver is a manual transmission MX-5 which I have been driving for ten years so I am used to manual trannys. I have not played with the manual mode of the RX350 but probably will soon. Without a clutch it will be quite a novelty.
I can see playing with it in stop and go traffic to switch gears from 1st to 2nd and back just to do some braking using the engine instead of stepping on the pedal. Other than that I dont see much use around here. We dont get snow here in Texas and its almost flat everywhere.
Old 12-15-09, 05:56 AM
The G Man
The G Man's Avatar
These manual shifter are fun at first if you never had one before, but the novelty will wear off fast. It just doesn’t have the reaction time of a manual clutch. If you try to accelerate fast with it, it will not shift fast enough. Lexus do have sport manual shifters that will shift very fast, but that is found in the IS-F only. The manual shift is ok for engine braking while towing and going down a hill, but that will put a very heavy load on your transmission. Unless you are towing a heavy load and the brakes are heating too much and fading, I would not use your transmission to slow down a car, brake pads are much cheaper to replace than transmissions.
Old 12-15-09, 07:16 AM
LeoDLion
LeoDLion's Avatar
Originally Posted by The G Man
... I would not use your transmission to slow down a car, brake pads are much cheaper to replace than transmissions.
In stop and go rush hour traffic, you brake a lot. Your knee is more expensive than your transmission.
Old 12-15-09, 04:03 PM
jimmyford1
jimmyford1's Avatar
Your 450h will have a Continually Variable Transmission and no gears per se.
Old 12-16-09, 08:26 AM
pulp
pulp's Avatar
since my previous car was a manual, i played with the sports mode for while after i got the RX but like other said, the novelty wears off quickly and i havn't used it at all after that.
i remember when i used it that no matter how fast or slow i was going it would always start off in 4th gear which is a little annoying.
Old 12-16-09, 08:33 AM
timgs300
timgs300's Avatar
I love the manual sport mode. However, my wife always prevents me from using it as she doesn't want me "messing up" her car.
Old 12-16-09, 11:48 AM
The G Man
The G Man's Avatar
Tell your wife you cannot mess up her car, the computer will stop you before you do that.
Old 12-16-09, 02:59 PM
Islanti
Islanti's Avatar
I came to my RX350 from a Mustang and manual Corolla so I find myself reaching with my left foot all the time. I've avoided Sport shifting because I've only got 350 miles on it. I wanted to get a good feel for the RX in normal drive. Have to start manual shifting soon though.
Old 12-16-09, 04:57 PM
Btmnk21
Btmnk21's Avatar
Was great going up and down Mt. Washington
Old 12-17-09, 12:31 AM
RXSF
RXSF's Avatar
how do you know when to upshift on the 450h?
anyways, definately novelty. i dont like using mine. plus, each upshift takes like 2 seconds...
dchan865
RX - 4th Gen (2016-2022)
03-09-19 04:01 PM
Nimo
GS F (2016-present)
03-15-18 05:22 AM
gdcheng
NX - 1st Gen (2015-2021)
05-13-15 07:13 PM
spotxc
03-30-14 02:17 PM
Jimt9
08-06-13 07:35 PM
Quick Reply: How Many of You Shift in Sport Mode?
