Go Back   Club Lexus Forums > Lexus Model Forums > RX Models > RX - Third Generation
Thread Tools Display Modes
Old 03-21-09, 07:54 PM   #1
itrcb4
Trader Score: (0)
Default When to use "ECT Snow" and "AWD Lock" feature?
Just looked through the manual and want to get some real-world insight from you folks..
So just when do you use "ECT Snow" ? A friend of mine told me it's no more than starting in 2nd gear... is that true even for a 2010 RX?
How about "AWD Lock" ?
Thanks
itrcb4 is offline   Reply With Quote
Old 03-21-09, 10:52 PM   #2
iKenn
Just call me "Sprinkes"
Trader Score: (0)
iKenn's Avatar
Send a message via AIM to iKenn
Use ECT Snow when its snowing. I also like to use it in traffic. It delays the throttle response.
I have no clue about the AWD lock though.
iKenn is offline   Reply With Quote
Old 03-21-09, 11:20 PM   #3
Christian8
Trader Score: (0)
Christian8's Avatar
Send a message via AIM to Christian8
your friend is correct. ECT Snow starts you on second gear instead of first, thus delaying a faster acceleration. I had no idea that there was an AWD lock button though. When did that happen? I have a 99 rx awd and don't have that button .lol
__________________
Get on, Get in, Hold on, Shut up
Quote:
Never argue with a stupid person... they will drag you down to their level and beat you with experience.
1999 Lexus RX300/AWD/Venetian Red Pearl/K&N filter/'01 exhaust accordion bend conversion
-99 Venetian Red Pearl Lexus RX300 AWD
-04 Silver Nissan Sentra 1.8
Christian8 is offline   Reply With Quote
Old 03-22-09, 07:51 AM   #4
tfischer
Trader Score: (0)
tfischer's Avatar
I have no AWD lock button on my '04, and was under the impression that the '10 was the first RX with that button, because the '10 is the first RX that is normally in Front Wheel Drive unless the system detects slipping. The previous RXs drive in a 50/50 front/back mode, and redirect power as needed upon the detection of slippage. The '10 should give slightly better mpg.
As for the "snow" button, I have found it useless; I'm not sure it is even attached to anything.
__________________
2002 SC430 Black/Ecru
First Edition (April 2001)
2004 RX330 w Nav/ML
and Thundercloud Grill
tfischer is offline   Reply With Quote
Old 03-22-09, 05:04 PM   #5
meowmix52
Trader Score: (0)
The ECT snow button like others said simply skips first gear and you start on second when pressing the gas pedal. This helps you gain more stability and control, not to mention it is MUCH harder to accelerate and the car feels heavier and more "bogged down."
meowmix52 is offline   Reply With Quote
Old 03-22-09, 06:54 PM   #6
itrcb4
Trader Score: (0)
The manual did suggest that "All Wheel lock" allows equal distribution of power to all wheels, instead of having the onboard chip decide to switch from FWD to AWD pending conditions, etc.
I guess I'll have to do some experiment myself at an empty parking lot when it snows next
Old 03-22-09, 08:16 PM   #7
RXSF
Trader Score: (0)
RXSF's Avatar
the snow button as people have said starts the car in second gear but i dont think you will ever need to use it.
the awd lock is new for the 2010 RX because it isnt full time awd and only activates the rear wheels when there is slippage. this lock buton turns on the rear wheels until like 10 mph
__________________
2004 RX330, 2002 IS300, 2009 C350
Past Lexus in the garage- 1999 RX300
RXSF is offline   Reply With Quote
Old 03-23-09, 07:12 AM   #8
The G Man
Trader Score: (0)
The 2010 RX AWD is a mostly a FWD drive car, the computer sends power to the rear wheel when it detects slippage or during accelartion from a stop. The 4WD lock button will lock in power to all 4 wheels, it also turns itself off at a certain speed, I believe its somewhere between 20 to 30 MPH, someone need to check the owner's manual. The 4WD lock button is very usefull when you get stuck in your driveway or for driving in heavy snow. Do not turn on your 4WD lock button when driving on dry pavement.
The G Man is offline   Reply With Quote
Old 04-21-09, 04:17 PM   #9
rxets
Trader Score: (0)
rxets's Avatar
Wink
Although most of ppl have known this answer, let me put words here to benefit anyone checking this thread.
As per the brochure says, AWD Lock:
On loose or slick surfaces, Lock mode can be used to distribute power evently between the front and rear wheels to help improve traction. Once the vehicle reaches 40 mph, the mode is automatically disengaged.
rxets is offline   Reply With Quote
Old 04-22-09, 05:45 AM   #10
The G Man
Trader Score: (0)
40 MPH huh, seems like Lexus made improvment to the system. The last gen on the RAV4 only allow lock uo to 28 MPH or something like that.
Old 04-22-09, 07:38 PM   #11
gtlegendz
Trader Score: (0)
i got the 2010 rx350 this week..i wanna put HID's 6000k for the fog lights..n the headlights r 4300k which is super white..the 6000k is slightly blue...think its will look nice?
gtlegendz is offline   Reply With Quote
Old 04-23-09, 05:40 AM   #12
The G Man
Trader Score: (0)
You should change the headlights to 6000K as well.
Old 04-24-09, 10:10 PM   #13
RXSF
Trader Score: (0)
RXSF's Avatar
just checked the 2010 350 manual and it says that lock cancels when vehicle speed exceeds 25 mph or 40 kmh
__________________
Old 04-24-09, 10:52 PM   #14
rxets
Trader Score: (0)
rxets's Avatar
Quote:
1 mile is around 1.6 KM. This number looks right. If so, Lexus got to correct RX brochure page 31. Dunno.
Can someone try it? Thanks.
Old 04-28-09, 12:49 PM   #15
The G Man
Trader Score: (0)
Ahhhh, so its the same system as the RAV4 then.
Tags
2000, 40, 4wd, awd, buton, disengage, ect, feature, lexus, lock, mph, rav4, rx300, snow, switch
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Go
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
