RX 330: Programming Door Locks
Old May 19, 2003 | 08:37 AM
Daddy-O's Avatar
Daddy-O
Default RX 330: Programming Door Locks
You can set the following auto door locking and unlocking functions.
All times must be EXACT or it will not work.
(A) Locking linked with the shift position
All the doors are locked automatically when the selector lever is moved out of the "P" position with the ignition switch in the "ON" position. This is supposed to be the default setting for new vehicles.
(B) Unlocking linked with the shift position
All the door are unlocked automatically when the selector lever is moved to the "P" position with the switch in the "ON" position.
(C) Locking linked with the vehicle speed.
All the doors are automatically locked when the vehicle speed reached 12 mph or higher. However, if any door is unlocked during driving, the auto function will not operate until the unlocked door is opened once.
(D) All the doors are unlocked automatically when the driver's door is opened within 10 seconds after the ignition switch is turned from "ON" to the "ACC" or "LOCK" position.
Setting the functions
1. Close all the doors.
2. Turn the ignition switch to the "ON" position.
3. Within 10 seconds after the ignition switch is turned to the "ON" position;
+To set function (A)
Push and hold the front of the power door lock switch for 5 seconds
with the selector lever in the "P" position.
+To set function (B)
Push and hold the rear of the power door lock switch for 5 seconds
with the selector switch in the "P" position.
+To set fuction (C)
with the selector switch in any position except "P".
+To set function (D)
All the doors are automatically locked and unlocked when you release the power door lock switch. This indicates that the function is set. If all the doors do not lock and unlock, the time the switch was held may have been too short or too long. Perform the procedure over again starting at step 1.
If you wish to cancel a function, repeat the procedure.
Each time you perform the procedure, the function is set or cancelled.
Good luck.
Old May 19, 2003 | 10:52 AM
cfgross's Avatar
cfgross
Is there a way to program it to do "noe of the above"? In other words don't lock or unlock the doors with shift position, vehicle movement, etc.
Craig
Old May 19, 2003 | 11:29 AM
j4ydubs's Avatar
j4ydubs
The default setting is (A), so to disable it, do the procedure for A. It's a toggle.
John
marty99
RX - 1st Gen (1999-2003)
12
Sep 22, 2022 05:03 PM
Kbach
GX - 1st Gen (2003-2009)
60
Mar 6, 2018 09:24 AM
Kendig
Jul 2, 2009 03:11 AM
rfong
Sep 16, 2006 10:34 AM
FunGuy
Jan 12, 2006 08:22 PM
