What adhesive for rain detector?
My 330 had a new windshield installed prior to purchase and shortly after, the rain sensor module came loose. Cleaned things up and epoxied bracket in place, and about a year later it came loose again. Seems temperature related - a hot sunny day and the epoxy loses adhesion. I'm ready to try again but at odds as to what adhesive to use.
Any long term successes out there?
Thanks,
Bruce
Thanks,
Bruce
Thanks,
Bruce
Thanks,
Bruce
http://www.ebay.com/itm/RAIN-LIGHT-S...-/281671918141
Rain sensor gel pad attachment
Sensor is attached with gel like pad. I my Rx it came loose while I needed to deattach it for installing dash cam in same wiring. I would need to replace the pad too as the sensitivity change after it, the sensor is not completely against the windscreen.
[QUOTE=rns;
Sensor is attached with gel like pad. I my Rx it came loose while I needed to deattach it for installing dash cam in same wiring. I would need to replace the pad too as the sensitivity change after it, the sensor is not completely against the windscreen.[/QUOTE]
The gel pad does not hold the sensor in place. It provides an optical path from the windshield to the sensor and must make good physical contact with both.
There is a clip on the bottom of the sensor module that when pulled downward releases the module from a rectangular metal bracket The bracket should be firmly attached to the windshield. If the bracket has detached from the windshield, it will be in the sensor module. Release it with the clip.
The bracket on mine came loose from the windshield, so I epoxied the bracket back onto the windshield after carefully cleaning all surfaces, attached a new gel pad to the sensor and carefully placed it on the bracket. Slide the clip into place which will put compression on the gel pad
One thing to note: If you disconnect the white connector plug, the wipers will revert to interval action in the auto mode - Which you may prefer!
Maybe try like this, they are strong and in pictures it looks like the sensor has been originally with tape in place. Wipe the windscreen area with some alcohol, isopropanol or any alike glue remover before installing if you didn't do that yet.
http://www.ebay.com/itm/3M-3614-Scot...-/231546625900
The metal bracket needs to be glued to the windscreen with rear mirror pad glue. You should not use 2 sided tape.
The gel pad is then placed in the center and the plastic case sat onto the bracket. (clip wire connector back in 1st if removed)
There is a slide out clip on the bottom of the plastic part.
This is moved out one inch to remove sensor off windscreen.
When you place it back onto the windscreen you then slide the clip back in whilst exerting a small amount of pressure on the sensor assembly.
brbradbury (03-27-17)
Funny thing, I found that 3M automotive trim mounting tape did the best for me. The glues I used did not do well with temperature changes, but the 3M stuff sticks like you can't believe. Just trim to fit with a razor blade and get it right the first time as you won't be able to move it once stuck to the windshield. Mine has been on for over 3 years now.
But if it works .. great.
adman0468
12-14-14 06:29 AM
