Rx330 rear door issue. Sometimes it works, sometimes it doesn't
Old 03-24-15, 02:45 PM
ADAM P
ADAM P's Avatar
Default Rx330 rear door issue. Sometimes it works, sometimes it doesn't
After owning the truck for a little over a year I figure it's time to fix the little stuff staring off with the rear door. When pressing any of the 3 buttons to open/close it I get it to work 50% of the time. That being said, I can't pinpoint a specific bad part. Anyone else have this problem? Thanks guys!
Old 03-24-15, 08:08 PM
LSBen
LSBen's Avatar
I have the same problem on my 04 RX330. The rear door doesn't open only when its really cold out which is about 20% of the time. I think its electrical. The button on the dash or remote wont open it. When the weather warms up, then it works fine. Unless the strut is going bad, but if that is the case, then it should stop working altogether and not be able to hold the rear door open.
Old 03-25-15, 07:46 AM
robbyk
robbyk's Avatar
I have the same problem with both of my side mirrors, they work weather dependent. The driver side mirror works most of the time but a little lethargic, the passenger side does not work at all 90% of the time.
Yesterday I took the it to Lexus, as I have extended warranty in force, and they said the actuators need to be replaced.
When I first showed up to the service department and told them about the problem, he said the actuators need to be replaced, aren't you glad you have the extended warranty because they are not cheap, meanwhile I am driving a nice loaner with only 7,000 miles.
I am assuming, by the description of your issue, that the actuator for your rear hatch needs to be replaced because it operates based on weather conditions and based on what Lexus said is wrong with both of my side mirrors. If it didn't work at all I would suggest to look at other electrical components.
Old 03-25-15, 08:30 AM
paul29
paul29's Avatar
I had the same problem on a 2010 Rx. Try locking then unlocking your doors via the remote or the all door inside switch on the armrest, leaving it in unlock position then try the rear door hatch switch/s. If mine fails to open I reset as above and then all options to open the hatch work ie the inside switch, the switch on the hatch and the remote fob hatch switch. When it fails to open it acts as if the switches or wiring are disconnected and this reset of the locks does the trick.
Old 03-25-15, 10:16 AM
jakenbake
jakenbake's Avatar
It only works 50% of the time with closing also? Not just opening?
Old 03-25-15, 10:53 AM
ADAM P
ADAM P's Avatar
Yes 50% of the time on lock open or close. I'll try the lock/unlock to test that out this afternoon. I know it's one of those things that the dealer will start throwing parts at until something works so I'd rather try it myself. Anyone replace the actuator before? Any threads on it?
Old 03-25-15, 11:04 AM
paul29
paul29's Avatar
On my RX it only fails when trying to open, the beeper on the dash switch also sounds but nothing happens. Once I get it to open with a lock unlock cycle it works ok open and close until the next time. There must be an operation that I am activating that leaves the rear hatch itself in lock position.
Old 03-25-15, 05:20 PM
ADAM P
ADAM P's Avatar
None of the above worked. I'm going to say it works 25% of the time now lol
Old 03-25-15, 05:26 PM
paul29
paul29's Avatar
Not good. $$$
Old 03-25-15, 05:53 PM
robbyk
robbyk's Avatar
Got my RX330 back, both actuators replaced ( L & R ). Total cost was $700, discounted rate. If I had to pay out of pocket I would be close to $900. Extended warranty work is at a discounted rate.
P
Old 03-25-15, 07:42 PM
ADAM P
ADAM P's Avatar
Ouch. My moms driving it now while I'm out of town and she's taking it to her Indy shop Friday. Will update
Old 03-30-15, 03:50 PM
jakenbake
jakenbake's Avatar
If it was only doing it when you try to open, I would say its the struts. But since it does it when you close too I am clueless.
Old 03-30-15, 05:57 PM
ADAM P
ADAM P's Avatar
Her shop said they don't want to mess with it.
I'm assuming it's a single part and that someone has been here before. Fingers crossed
Old 03-31-15, 04:03 PM
robbyk
robbyk's Avatar
Let us know how it goes.
Old 04-01-15, 07:17 AM
draco
draco's Avatar
I sometimes have the issue but only on open. I "reset" by opening it manually and then closing it firmly. Fixes it up till the next it happens.
sbklf
05-12-23 04:26 PM
rellie1241
07-21-17 03:19 PM
RX330inMD
12-05-14 04:56 PM
jsperrella
12-16-12 08:07 AM
spike owen
11-15-05 07:06 AM
Quick Reply: Rx330 rear door issue. Sometimes it works, sometimes it doesn't
