Check Airconditioning message RX350
Old 02-08-15, 03:47 PM
tizelwazze
tizelwazze's Avatar
Default Check Airconditioning message RX350
Hey guys,
So i've been searching the internet for a solution to my Check Airconditioning message but couldn't find anything,
Some say it's the relay , and others say that it's nothing wrong with it,
Well i tried the relay ,,, bought same part number, but this relay was from a Prius,
(but exakt same partnr) ,
What happend was that The AC wouldnt start Automatically, i had to pust start everytime the car started, but there where no Check Airconditioning message ,
Changed back to the Old relay and the Ac Went on Auto but immediatly started flashing and Check Airconditioning message was back.
The question is,,, do we know exactly what's causing the Check Airconditioning message??
I mean,,,, this has been going on for quite a time , so someone has to know ?? right?
My car is a RX350 -2006 AWD
\\ KenZo ,,,From Sweden
Old 02-08-15, 04:01 PM
Rainbird
Rainbird's Avatar
I have had this issue maybe three times over several years. Turning the AC off and back on seems to eliminate the warning. Fortunately the problem has not returned. Here is a link to a previous discussion of the "Check Air conditioning message.
https://www.clublexus.com/forums/rx-...r-message.html
Old 02-08-15, 04:13 PM
Rainbird
Rainbird's Avatar
Here is the Lexus Technical Service Bulletin on this exact problem.
File Type: pdf
Old 02-08-15, 04:16 PM
tizelwazze
tizelwazze's Avatar
I get the message every startup
Old 02-08-15, 04:21 PM
tizelwazze
tizelwazze's Avatar
Wow,, thank you ,, exactly what i was looking for
Hope my dealer takes this on warranty, but i Think not,, my rx350 has done 15,500 kilometers
Old 02-08-15, 04:24 PM
Rainbird
Rainbird's Avatar
That doesn't sound good at all. The Air Conditioner Amplifier Assembly is an expensive part. Replacing that may be your only option.
Old 02-08-15, 04:30 PM
tizelwazze
tizelwazze's Avatar
well i scanned ebay and managed to find the "new" upgraded amp for aprox 120$,
But i'm going to check with my dealer first , maybe it's a "recall"
Old 02-08-15, 04:34 PM
Rainbird
Rainbird's Avatar
Good luck, I hope it works out for you and welcome to Club Lexus.
Old 02-08-15, 04:40 PM
tizelwazze
tizelwazze's Avatar
thank you for the help.
Will return later when it's fixed, and give u an update
Old 02-08-15, 05:24 PM
Rainbird
Rainbird's Avatar
I appreciate that. So many times we give advice and answers and get no feedback. Your experience with this A/C problem can very possibility help other CL members.
tawm (08-04-21)
Old 02-10-15, 02:40 PM
Wht95scort
Wht95scort's Avatar
Are you sure about your vehicles year? If it's a 2006 then you have an rx330. This tsb won't apply. However there is one for 04-06 for the same issue.
Old 02-10-15, 02:46 PM
Rainbird
Rainbird's Avatar
He is in Sweden. I believe the Asian and European model RX350 started with the 2006 model year. 2007 for the US and Canada.
Old 02-16-15, 04:55 AM
tizelwazze
tizelwazze's Avatar
Yes i'm sure , but thanks for the info ,
My English is not that good with "car terms" where is this module hiding?
the instructions says:
1. Remove the RH front door scuff plate.
2. Remove the RH cowl side trim sub assembly
Old 02-16-15, 11:18 AM
Rainbird
Rainbird's Avatar
These are two images from the 2007 RX Service Manual.
Attached Thumbnails Check Airconditioning message RX350-hvac.jpg   Check Airconditioning message RX350-hvac-amp.jpg
Old 02-16-15, 04:35 PM
tizelwazze
tizelwazze's Avatar
thank you, now i just have to order the damn thing
Quick Reply: Check Airconditioning message RX350
