squeal on cold starts
Old 02-04-15, 11:09 AM
LazarusLng
LazarusLng's Avatar
Default squeal on cold starts
2004 95K. Over the past month or so there is a short squak or squeal when starting the motor. This has only been happening when the temperature outside is 20 degrees or below. The belts are new, including the timing belt. What would you check first?
Old 02-04-15, 11:15 AM
litzdog911
litzdog911's Avatar
Did this start before or after the new belts were installed?
Old 02-04-15, 11:53 AM
NVAKeith
NVAKeith's Avatar
Re-tension the belts.
Old 02-04-15, 03:41 PM
LazarusLng
LazarusLng's Avatar
Will check that first. It happened after belts installed.
Old 02-06-15, 11:46 AM
Barry2522
Barry2522's Avatar
.I didn't think you could adjust the belt tension manually . The tensioner could be weak letting the belt slip .
Old 02-06-15, 01:15 PM
AussieAuto
AussieAuto's Avatar
You can adjust both power steering and alternator/air cond belts, most likely just need a little tweak.
Old 02-07-15, 11:27 AM
01LEXPL
01LEXPL's Avatar
I found it was power steering in my case...
It got progressively worse with time and very much weather dependent, when it was humid, and cold.
Changed the belt, did a PS flush with new T4 ATF. Ended up getting a new PS pump. No more squeal.
Old 02-07-15, 03:02 PM
LazarusLng
LazarusLng's Avatar
I was suspecting the PS pump. I also have a slight whine when turning the wheel, only briefly, when it is cold.
fuzionx23
03-12-17 01:17 PM
Braz60
07-15-16 08:13 AM
jgrosey
09-11-14 07:25 AM
victorvaj
Performance & Maintenance
01-21-13 10:00 PM
SilverSled
01-07-10 07:13 AM
Quick Reply: squeal on cold starts
