05 rx330 sunroof open and closed button weird..
I just bought 05 rx330 and the sunroof open button and the tilt button both works. My question is when you want to close it, u cant just press it all the way, i guess you have press it and play by ur feeling correct? If you press it all the way it will open again. Idk is it happening to you guys?.. Like my acura tl it closed when i press it all the way down. With lexus it will open again weirddd hmmmmmmm..
Jlmemt (05-05-24)
reprogramming
hold the tilt button till it does a full cycle of opening and closing the sun roof.
after that, your tilt and the sunroof button will work like it should
Jlmemt (05-05-24)
You will have to do the reset anytime the battery has been disconnected...Hold the tilt button the sunroof will tilt up, close, slide open, close and then you are set. It is also in the owners manual.
Jlmemt (05-05-24)
Please share the knowledge with me
I have A 06 LEXUS ES350 I went to open the sunroof. Only the back right side of the roof barely popped opened. And now it want close. I can hear the motor moving, but the roof want open or close back now. Thanks n advance
