Go Back   Club Lexus Forums > Lexus Model Forums > RX Models > RX - Second Generation
Sign in using an external account
Register Forgot Password?
Steering/Vehicle vibration @75mph
Thread Tools Search this Thread Display Modes
Old 12-14-14, 04:10 AM   #1
Foshoopd
Trader Score: (0)
Default Steering/Vehicle vibration @75mph
Hi,
So I've read a lot of the threads, especially the write-up by alchemist in reference to a vibration and what to replace. Through a round about way, in the last few weeks I've replaced:
-both CV axles
-font lower control arms with bushings and ball joints
-all 4 struts (KYB) and mounts
-Tires, Michelin Premier A/S road force balanced and vehicle aligned
Brakes/rotors were done about 20k miles ago as well.
Car really rides nice now, but when I get it on the highway, around 75mph I start picking up a slight vibration through the steering wheel. I can also feel it in the car to some extent before 75. It is very consistent, always there regardless of road conditions or day I drive it.
I'm looking for some more help here to see what else this could be. It is driving me nuts and I've spent a lot of time and money to this point with no resolution. The last thing I can think of is possibly the steering rack and tie rods (mine is seeping a bit, 120k on the car, but I check the fluid level regularly and have not added any fluid in 20k miles)
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
Foshoopd is offline   Reply With Quote
Old 12-14-14, 02:06 PM   #2
roadbike56
Trader Score: (0)
I had a similar problem when we purchased our RX350. I had the alignment checked, no problems. So we drove it for a while. Long story short, the dealer installed a brand new set of Sumitomo Touring LH tires just before we bought the car. After 1000 miles, the vibration stopped. I can only attribute the problem we had to tires getting broken in. You might want to see if the problem goes away after the Michelins are worn in. Alternately, I'd check the balance again.
roadbike56 is offline   Reply With Quote
Old 12-14-14, 07:29 PM   #3
alchemist
Trader Score: (1)
alchemist's Avatar
My vote is for steering rack as it is known issue. Youve basically changed everything that rotates except for the wheels.
If you can wait until spring i plan to change mine and will do full DIY write-up
__________________
2007 GS350
2006 RX330
alchemist is offline   Reply With Quote
Old 12-22-14, 06:50 AM   #4
robbyk
Trader Score: (0)
robbyk's Avatar
I had a similar problem, slight vibration around 75 MPH. In my case it turned out to be the rotors. I turned the rotors and replaced front brake pads with original Toyota parts, clips and shims, problem solved.
Every time I pushed the brKe pedal there was a slight vibration in the steering wheel, hardly noticeable but it was there. The wife never noticed it until we went on a long trip and I drove the car for about 1,000 miles.
robbyk is offline   Reply With Quote
Old 12-22-14, 02:39 PM   #5
trinh76
Trader Score: (0)
+1 on the steering rack. Get that inspected. Just had mine replaced along with hoses at Toyota due to a leak. No more vibrations at 75mph and steering is much better.
__________________
04 RX330 AWD
TC Grill
Quad Projector (OEM RX330 Projector 2.5" TSX-R clear lens *swap*
FX-R Projectors [bi-xenon / low/high beams])
LED Tails
trinh76 is offline   Reply With Quote
Old 12-23-14, 05:18 PM   #6
Bon
Trader Score: (0)
You didn't mention tie rods. I just fixed a vibration problem like you have and only replaced the lower ball joints and outer tie rods. I would have sworn that the ball joints and tie rods were good. Wrong! The shakes are gone.
__________________
Cars: 2001 LS430 UL Silver/Ecru (Sold); 2003 LX470 White/tan; 2006 SC430 Black/Saddle; 2004 RX330; 2008 Toyota Sienna Ltd; 2004 RX330
Cycles: 1999 Honda Valkyrie Interstate, 2000 Honda Valkyrie Supercharged; 1986 Yamaha V-Max; 1965 Honda 305 Dream
Bicycles: Specialized Tarmac
Bon is offline   Reply With Quote
Old 12-30-14, 10:25 PM   #7
Bikerdad
Trader Score: (0)
My new to me RX330 also gets really bad vibration at 120km/h with the winter tires. Doesn't do it with the summers. Winter tires need balancing?
Bikerdad is offline   Reply With Quote
Old 12-31-14, 06:18 AM   #8
Eliaquim
Trader Score: (0)
I was having this problem and here how it solved 'itself?':
Replaced all brake pads and the vibration was reduced.
Replaced sway bar end links and didn't really pay attention.
Than I replaced front struts (one was gone), inner and outer tie rods, as well as the ball joint. Problem solved.
Just look at you have done and compare to what I did. I hope it helps.
Eliaquim is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Intermittent Steering Wheel Vibration GS4hunnit GS - Second Generation 9 06-05-14 10:17 PM
Steering wheel shake in my new '08 greenchile ES350 (2007 - 2012) 11 12-16-13 08:32 AM
Shimmy On Steering Wheel Ariyanna ES300 and ES330 11 05-01-07 08:51 AM
vibration on my RX300 thomas1 RX - First Generation 3 02-10-07 09:15 AM
Vibration - Shimmy in front end BBLexus ES300 and ES330 12 12-30-06 12:34 AM
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
