transmission flush
Old 10-14-14, 02:56 PM
ajay60610
ajay60610's Avatar
Default transmission flush
Ref: 2009 RX-350 AWD, 90K
Talked to various people re: whether i should get a trans. flush or a drain and fill.....drain and fill only removes oil from trans. pan...maybe 3-4 qts..... a trans. flush removes all of the oil throughout the trans. system...maybe 8-9 qts......does it make sense to only remove part of the dirty oil [drain and fill]while leaving the remaining dirty oil within the trans. system......thanks for your help.
Old 10-14-14, 06:03 PM
txt
txt's Avatar
Drain & Fill is easy to do.
You can do several (3) D&F.l.
Each D&F will reduce the % of old ATF and by the 3rd D&F the ATF is almost all fresh.
Old 10-14-14, 06:10 PM
lexsc4
lexsc4's Avatar
Just do a drain and refill at 20K miles interval. I start using this 20K-miles interval at 80K miles and the shifts are smooth. You can get the WS fluid at ebay $37-40 shipped 4 quarts and bring it to your shop.
Old 10-14-14, 06:27 PM
jakenbake
jakenbake's Avatar
From everything that I have read, the flush runs a higher risk of damaging your transmission and the drain and fill is the way to go. If you have the transaxle cooler, the dealership will put the car's computer in service mode so that the pump for the cooler will pump all the old fluid out and the new fluid in.
Old 10-14-14, 06:46 PM
alchemist
alchemist's Avatar
Drain and fill every 30k and change the filter screen every 90k miles
Old 10-14-14, 08:57 PM
LSBen
LSBen's Avatar
I've only done drain and fill on my 01 LS430 now at 148k miles. On my recently acquired 04 RX330 with 188K miles, I just did a drain and fill. My Toyota Indy Mechanic recommended drain and fill with 30K intervals starting at 60K miles. He says he doesn't see cars come back with tranny issues on this schedule. Any my tranny oil was relatively clean to begin with at 188K so no need to do more than the recommended schedule.
Old 10-15-14, 07:47 AM
ajay60610
ajay60610's Avatar
Thanks for all those who commented on my post...appreciate your helpful comments.
Old 10-18-14, 01:10 PM
cdnewton
cdnewton's Avatar
To give a different opinion, I have had transmission fluid exchanges (14 quarts when they do it) every 30K on our RX330 .... just turned 190K and working great.
Old 10-18-14, 03:18 PM
spacecraft
spacecraft's Avatar
Where is it exactly?
Old 10-18-14, 03:50 PM
ajay60610
ajay60610's Avatar
Was told that my RX-350 AWD[90,000 miles] does not have a dip stick...if that's the case and i choose to do a drain and fill where is the intake for the new oil[about 4 quarts] ...sorry but i'm not a car person.....wanted to buy the toyota transmission oil from the lexus dealer[ $9.75/ quart] and bring it to an independent shop which has lower labor rates[i do trust this shop] but dealer parts guy didn't like that idea......any help would be appreciated.
If there is no dipstick then how does the dealer service guys know my transmission fluid is dirty.
Old 10-18-14, 08:40 PM
alchemist
alchemist's Avatar
https://www.clublexus.com/forums/rx-...iy-w-pics.html
Old 10-18-14, 10:38 PM
spacecraft
spacecraft's Avatar
Many thanks, great write-up indeed, which I had missed when it was posted.
Does anyone know if it's valid also for the 400h tranny?
Old 10-19-14, 07:37 AM
alchemist
alchemist's Avatar
You have to drain it to tell if dirty. Drain plug and fill plug are on the tranny. There is also a check plug to check the level at certain temp. I did a write-up for this for my gs350
Old 10-26-14, 07:21 AM
ajay60610
ajay60610's Avatar
RX-350 AWD,90,000......went to lexus dealer and asked for a transmission drain and fill and gasket change [per the responses from my original post]....took about 4 quarts.@$9.75/qt......dealer techs did the work but did NOT change the filter....only would do if i wanted a trans. flush@$100 more......i declined but now thinking i should have got this work done....should i go to and independent shop [ i do trust this shop] and ask for a trans. filter change only...should i buy the trans. filter online or at o'reilys'.....thks. for any responses...not a car guy and want to keep my car for another 30,000 miles.
Old 10-26-14, 07:43 AM
alchemist
alchemist's Avatar
If you are only keeping for 30k miles dont worry about it
Legitek
07-04-13 11:03 AM
Hollywoood
03-17-13 08:24 PM
cubbieblu7
IS - 1st Gen (2001-2005)
06-19-12 09:12 PM
IM QUIKR
02-10-10 02:31 PM
sxys_sc4
SC- 1st Gen (1992-2000)
06-26-01 06:22 PM
Quick Reply: transmission flush
