Please help - What engine oil to replace recommended
Old 09-18-14, 04:27 AM
Eliaquim
Eliaquim's Avatar
Default Please help - What engine oil to replace recommended
Hello again!
First I have to say that I read lots of threads on what engine oil is suitable for a 2004 Lexus RX330. And I know the manual says Toyota Genuine Motor Oil, 5w30. Problem is: There is no Toyota Genuine Motor Oil, 5w30 where I live.
Oil change time has arrived and I need your input on what to chose among the following options (Note that I live in a climate that is hotter than the USA and I normally do short trips, long ones once in a while and drive rather aggressively):
Lexus Genuine Oil (by Toyota), 5w40;
Galp Formula F or G 5w30 synthetic (cert by Ford, Opel and GM);
Comet 5w30 synthetic (made in South Africa);
Castrol Magnatec 5w30 synthetic (they say the one sold here is made in South Africa and not Germany)
Should I chose the oil for the brand and change from 5w30 to 5w40 or find another brand and remain with 5w30? That's the main point.
Notes:
Previous solution: used synthetic Castrol Magnatec 5w30 the first oil replacement I did on the 125000 miles car.
I really do not know what oil was there before, because I bought the car used and the previous owner just left decisions for the shops. Notice a perceptible but not to worry increase in engine noise. Did not notice any leaks.
Old 09-18-14, 06:06 AM
thomas1
thomas1's Avatar
I would stick with the Castrol Magnatec synthetic....5w40 would probably be your best bet in your warmer climate. The synthetic would give you the best overall protection regardless of temperature and also prevent sludge.
Old 09-18-14, 07:45 AM
Eliaquim
Eliaquim's Avatar
Thank you very much, Thomas1. I just checked and the 5w40 made by Toyota for Lexus (in United Arab Emirates) is also synthetic. Do you still think The 5w30 from Castrol is better?
Technically, or better, for may engine, what does change if I go from 5w30 to 5w40?
Old 09-18-14, 08:00 AM
mandyfig
mandyfig's Avatar
Stick to the 5W-30, good luck.
Old 09-19-14, 07:52 AM
Grumpa72
Grumpa72's Avatar
Honestly, any engine oil that is rated at "API Service SM" (written somewhere on the bottle) will work for your car. The oil cap specifies which grade and go from there. If I only had non-synthetic, I would shorten the oil change interval and be happy while driving.
Old 09-19-14, 08:03 AM
hypervish
hypervish's Avatar
What type of temperatures do you see there?
You should be fine with a 30 weight.
Old 09-19-14, 09:04 AM
Eliaquim
Eliaquim's Avatar
Most of the year it ranges from 66F to 93F. What do you think!
Old 09-19-14, 09:07 AM
Eliaquim
Eliaquim's Avatar
Thanks for you input, Grumpa!
How short would you make your interval?
Old 09-19-14, 10:02 AM
hypervish
hypervish's Avatar
Those are mild temps, a 5W-30 will serve you well! No need to move to a heavier 40 weight.
Old 09-19-14, 10:07 AM
Eliaquim
Eliaquim's Avatar
Thank you!
I just wanted to use the oil made by the brand, but I will keep using the Castrol Magnatec.
Old 09-19-14, 11:16 AM
Grumpa72
Grumpa72's Avatar
I have always changed my oil at 5000 mile intervals using Mobil 1 synthetic. In harsher and/or dusty environments I might be inclined to go 3-4000 using conventional oils. My BMW diesel has an 11000 mile change interval but I halve that for many reasons.
Old 09-19-14, 05:31 PM
lexsc4
lexsc4's Avatar
I always use Mobil 1 5W-30 and always stick with 5-5.5K miles intervals. Also always use Toyota OEM oil filters. I buy 10 filters at a time since it fits both my 08 Avalon and my wife's 08 RX350.
Old 09-19-14, 06:29 PM
rxonmymind
rxonmymind's Avatar
Another vote for Castro. I've poured over this subject at bobstheoilsguy forum and seems that Castrol motor oils is VERY good for high mileage cars.
Old 09-20-14, 01:32 PM
1koolfella
1koolfella's Avatar
I just put in some RedLine 5w30 and the car feels amazing. It was a noticeable difference for me. I picked up 6 quarts on Ebay and bought a half quart locally.
Old 09-24-14, 01:22 PM
Eliaquim
Eliaquim's Avatar
Yes, I also do 5000 even with synthetic
Quick Reply: Please help - What engine oil to replace recommended
