No way to open rear trunk manually?
Old 09-10-14, 01:35 PM
Randy25
Randy25's Avatar
Default No way to open rear trunk manually?
My battery died. The jumper cables are under the floor of the trunk. Obviously the trunk control button under dash or on key won't operate. The manual buttons that lift the floor are hidden under the trunk door. Am I out of luck?
Old 09-10-14, 02:17 PM
Rainbird
Rainbird's Avatar
Make sure the car is unlocked. Push in and pull up on the rubber trunk release on the rear door below the Lexus logo and above the license plate. I think this will work even with a dead battery.
Old 09-10-14, 03:11 PM
Randy25
Randy25's Avatar
Thank you. I did try that yesterday. But no go.
Old 09-10-14, 03:28 PM
Rainbird
Rainbird's Avatar
Your profile indicates your Lexus is a 2006 model. If that is the case and it has the factory battery, it almost certainly needs replacement. I would remove the battery and have it tested under load at an Auto Supply Store.
Old 09-10-14, 08:05 PM
jakenbake
jakenbake's Avatar
The only way to open the rear door when the battery is dead is to crawl in through one of the side doors. and open it from the inside. There is a little rectangle carpet patch on the rear hatch right above the lock mechanism. You pop out that carpet patch and there is a little lever inside you can move with your finger. That will release the back door and you can push it open.
Old 09-10-14, 08:18 PM
jakenbake
jakenbake's Avatar
Here are the pages from the owners manual.
Old 09-10-14, 08:50 PM
Carver
Carver's Avatar
Learn something new everyday!
Old 09-11-14, 01:57 PM
Randy25
Randy25's Avatar
Thank you Jakenbake! I didn't know that cover existed. I was able to open the rear door instantly.
Old 09-23-14, 11:09 PM
TriniLex
TriniLex's Avatar
Didnt want to start a whole new topic.
But how do I open my trunk manually with a good battery in check?
Seems like sometimes It opens manually and sometime automatic
Old 09-23-14, 11:23 PM
jakenbake
jakenbake's Avatar
Whether it opens manually or automatically is a setting the dealership has to program for you.
Najsgaj
10-19-20 04:20 PM
mcmahonbky
ES - 5th Gen (2007-2012)
28
02-26-20 03:17 PM
caha14
11-30-13 01:58 PM
dPtQu3
10-08-10 10:11 AM
herbsc430
06-25-09 12:03 PM
Quick Reply: No way to open rear trunk manually?
