RX 330 Antenna Mast replacement
Old 05-22-14, 07:25 PM
Eddie2086
Eddie2086's Avatar
Default RX 330 Antenna Mast replacement
hello folks. i went thru the carwash and my antenna mast cracked at the bottom...is this part easy to replace and is installation easy, or do i need a complete new antenna assembly..? thanks ed
Old 05-22-14, 07:57 PM
RX330inFL
RX330inFL's Avatar
Welcome to Club Lexus, Eddie2086.
If you are referring to the base itself, it is not easily replaced. How bad is it? Can you post a picture?
As with most topics regarding your RX, you will usually find an existing thread on the topic from past experiences. Such as:
https://www.clublexus.com/forums/rx-...mbly-help.html
Old 05-22-14, 09:59 PM
Eddie2086
Eddie2086's Avatar
the base is fine, its just the 7 inch antenna . i was wondering if it just screws off
Old 05-22-14, 10:16 PM
Carver
Carver's Avatar
Yes, it just screws in. I replaced mine about three years ago with a fin antenna and I may have the old mast in the car somewhere. I'll take a look and if it's still around you are welcome to it. Don't get too excited, I haven't seen it in years but I rarely throw those kinds of things away. If I find it I will PM for your mailing address.
Old 05-22-14, 10:44 PM
RX330inFL
RX330inFL's Avatar
The various pieces:
http://lexus.sewellparts.com/oem-cat...X330-2004.html
Old 05-23-14, 08:33 AM
mandyfig
mandyfig's Avatar
I attempted to repair a friend's RX antenna and it needs replacement of the base. It is an involved DIY. You have to go under the roof liner.
Maybe Carver can shed light on how easy it was to replace with the sharkfin antenna.
Carver?
Old 05-23-14, 09:52 AM
Carver
Carver's Avatar
Two minute job. The base of the antenna stays in place. The swivel part of the base where the mast screws in is where you attach the wire antenna contained in the fin. Clean the area with alcohol, peel the double sided tape, align the fin and stick it over the base, press down. Done.
Old 05-23-14, 10:38 AM
mandyfig
mandyfig's Avatar
Carver thanks. I almost bought one. It is a big sharkfin that encloses the whole base! Thanks for jogging my memory which nowadays need a lot of jogging...
Old 05-23-14, 11:42 AM
Rainbird
Rainbird's Avatar
What may take getting used too with a shark fin antenna is the off center look.
Old 05-23-14, 01:07 PM
mandyfig
mandyfig's Avatar
Mine, I just fold it forward, not as noticeable, however my top is bald. The roof rack has been off since I bought the car, after they replaced the cross bar due to a TSB.
mandyfig
mandyfig's Avatar
I have brand new cross bars sitting in the attic.
Old 05-23-14, 01:33 PM
Carver
Carver's Avatar
The black stick is off center, does that look odd? The fin looks good, much better than the stick. Carwash proof so far.
Old 05-23-14, 02:27 PM
Rainbird
Rainbird's Avatar
It does look nice. Did you have to get it painted to match the car?
Old 05-23-14, 02:41 PM
RX330inFL
RX330inFL's Avatar
White comes from Beat-Sonic in the correct color code for the RX Crystal White. Not sure about other colors.
http://www.beatsonicusa.com/shark-fi...sal/fda4w.html
Old 06-05-14, 08:32 AM
lexilexus
lexilexus's Avatar
and a alternate replacement can be had at cravenspeed "the stubby"for $25
CRMC-0703-TF fits lexus and nissan
Quick Reply: RX 330 Antenna Mast replacement
