Old 12-15-14, 03:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Tires and Wheels Guide
Print Wikipost
Check your tire pressure
Old 05-05-14, 10:15 AM
Band
Band's Avatar
Default Check your tire pressure
I got a coupon from the Les Schwab tire co (big in the great northwest) for a free tire rotation. After the rotation, started noticing my steering wheel was just a touch off center on a level road. Checked tire pressure: two left tires at 30 lbs (where I set them) and right two tires were at 40 lbs.
There are a few lessons to be learned here. Have never understood why people think more air is better.
Always check your tire pressure after a service!
Old 05-05-14, 02:44 PM
RX3302004
RX3302004's Avatar
I have 2 vehicles to go to my local Toyota dealer for regular service. They both always come back with air pressure at 35psi no matter what the door jamb sticker says. I know this and go out immediately and reduce the air pressure to the recommended #.
Old 05-05-14, 05:21 PM
kiwi
kiwi's Avatar
i always set mine to 35 for fuel economy.
i do keep an eye on tire wear, and after 5 years of 35 PSI, i have never had the center worn out on my tires.
Old 05-06-14, 06:17 AM
jfelbab
jfelbab's Avatar
My tech sets the tires at 35psi in the winter months and 32psi in the summer. The logic is that the temperature in the garage is typically around 30° warmer than the outside temp in the winter. (35psi @ 68°F inside = 32psi @ 38° outside)
Tires should be checked and adjusted regularly as conditions change. 1 psi is gained or lost for every 10° temperature change, whether using air or nitrogen.
Good read on nitrogen vs. air for those curious: http://www.tirerack.com/tires/tirete...jsp?techid=191
colfax
05-21-18 06:32 AM
cezar9
01-11-16 06:05 PM
lexman52
11-29-15 02:04 PM
Johnny
05-13-07 08:12 PM
electro992
13
05-20-04 10:41 AM
Quick Reply: Check your tire pressure
