Rear Bumper paint spider Web
Old 04-19-14, 01:48 PM
Rushore
Rushore's Avatar
Default Rear Bumper paint spider Web
Hey Folks,
Very excited, just bought a used 2005 RX 330 and everything is perfect except for my left rear corner which has a spider paint crack. Any suggestions if this is a DIY or is it a body shop repair. Hate to have to spend $500 + for this. The size is about 4x6.
Old 04-19-14, 03:20 PM
HtownBlue
HtownBlue's Avatar
I have the same thing my man. Gonna have to have bumper repainted. Over time the plastics bumper expands and contracts so many times it begins to slightly deform and cause the cracks.
Old 04-19-14, 05:29 PM
Rushore
Rushore's Avatar
Thanks Blue how much should I expect to pay? Is there anyway that just the damage area can be touched up?
Old 04-19-14, 08:12 PM
HtownBlue
HtownBlue's Avatar
I'm no body guy, but you might be able to get by with a touch up job but it won't look stock because you've got to sand that area to get rid of the cracks etc.
Old 04-20-14, 09:40 AM
Rushore
Rushore's Avatar
Thanks Blue looking at the other posts it looks like up to $700. Has anyone used Maaco before?
Old 04-20-14, 10:42 AM
RX330inFL
RX330inFL's Avatar
Don't cheap out. The paint on your RX is a three step process: paint, pearl, clear. Doesn't mean you need to go to the dealer, but I would at least make sure whichever shop you use does Lexus paint on a regular basis. Otherwise, you will end up with a paint job where the bumper does not match the rest of the vehicle. The pearl is a bear to match.
Also, if you have the whole bumper painted you will also want a new step pad. Do not let them tape and paint around it. Once the step pad has been removed it cannot be put back on proper. Best just to install a new one.
Old 04-20-14, 05:49 PM
Rushore
Rushore's Avatar
Thanks FL I'm going to the body shop tomorrow. Much appreciated!
Old 04-20-14, 05:51 PM
1sWt2GS
1sWt2GS's Avatar
To be quite honest you need to probably paint the whole bumper again.
Old 04-20-14, 06:06 PM
Zoso08RX
Zoso08RX's Avatar
Yeah man ... stay away from Maco.
Get it done right.
Old 04-21-14, 11:01 AM
Rushore
Rushore's Avatar
Just got an estimate from my local body shop for $700. Includes taking off the bumper & repainting. I guess that's the going rate...
Old 04-21-14, 11:12 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
Maaco? LOL
Old 04-21-14, 01:58 PM
kevs98GS4
kevs98GS4's Avatar
WOW could get that done for $200 here in Atlanta. that's non macco good job
Old 04-21-14, 02:53 PM
RX330inFL
RX330inFL's Avatar
I assume you are referring to just sanding and painting only that one area of the bumper. Perhaps you could get it done in your area for $200, though I might call your bluff on that one and would want to see an official quote to believe it. Regardless, as I mentioned above this is a three step process on the paint and it is doubtful you could get a proper blend of the paint with the rest of the bumper and especially the pearl by shooting just that one area. If it were not a pearl paint I might be in agreement with you a bit more.
A new step pad is going to run $90, from Sewell even with our discount, and if you are going to paint the whole bumper you definitely do not want them to tape around this for the job. Add time to remove the bumper, tape and prep for a proper paint job and you are over $200 before you begin. Not a lot of paint needed for the job, but the paints are still not cheap and needs to be mixed. Hard to stay in business to offer all this up at $200.
So, this is definitely a case of you get what you pay for. Try to do it cheap and you will get something you will perhaps regret doing. Not saying $700 is the going rate as that depends as much on area as the shop used.
Old 04-22-14, 06:51 AM
kevs98GS4
kevs98GS4's Avatar
No reason what so ever to replace the step pad. It will pop right out and from the pic doesn't show any problems with it. Save $90 right there.
Yes I get bumpers painted here in Atlanta all the time for $150-200. I run a dealership. Call my bluff anytime you want and I can produce receipt after receipt of proof. And yes they paint the whole bumper not just the corner.
Old 04-22-14, 08:39 AM
Rushore
Rushore's Avatar
Hey Folks,
Just got an estimate for $300 from Carmetics. They would just paint the damaged area. Has anyone ever used them?
Quick Reply: Rear Bumper paint spider Web
