Need some advice on vibration issues on a 2007 RX350
Old 04-18-14, 06:36 AM
Omidjuly4
Omidjuly4's Avatar
Default Need some advice on vibration issues on a 2007 RX350
Hi guys
I have a RX350 2007 i have vibrations that i feel mostley on the steering wheel.
I have new tiers and they are balanced the brakes and rotors are fine to. The vibrations ocure after 65mph and up. if im driving 75mph an let go of the accelerator pedal i feel the vibrations. I actually tried to go 120mph and it was ok until i released the accelerator pedal.
any ideas ?
Old 04-18-14, 06:51 AM
thomas1
thomas1's Avatar
Sounds like bad drive shafts
Old 04-18-14, 06:57 AM
Omidjuly4
Omidjuly4's Avatar
shouldent it vibrate al the time then? even in lowerspeeds when the rpm can be higher?
Old 04-18-14, 07:25 AM
thomas1
thomas1's Avatar
I take it back, You could still have a tire issue, maybe you need to find a road force balance machine to make sure the tires truly are balanced. One other place to look is at the lower control arms bushing on the front end. Maybe the bushings are torn.
Old 04-18-14, 08:23 AM
Omidjuly4
Omidjuly4's Avatar
Thanks Thomas just checked that out and they looked good
Old 04-18-14, 10:15 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
try re-balance your tires first....
Old 04-18-14, 10:31 AM
HtownBlue
HtownBlue's Avatar
If it's not your tires (unlikely that it is tires), it's your CV AXLES. The carrier bearing and cv joints wear out and causes vibration at higher speeds when the axle is not under tourque from acceleration. I'd bet money on it.
Old 04-18-14, 12:09 PM
Omidjuly4
Omidjuly4's Avatar
Ok thanks a lot i need to check that out then
Maracus
10-15-15 01:24 PM
ronnymo
ES - 5th Gen (2007-2012)
09-20-15 12:35 PM
lgirard50
08-26-15 05:25 PM
johncoby
11-20-14 11:20 AM
dbui
RX - 1st Gen (1999-2003)
12-19-11 05:26 AM
Quick Reply: Need some advice on vibration issues on a 2007 RX350
