2nd Gen Maintenance Schedule
Ok, my brain is turning to mush doing searches, reading the sticky's, etc. I'm looking for the following mileage times to change fluids. I know Lexus says one thing (though not in my manual ???) I was told they leave it up to the dealer to decide, which sounds like they want more maintenance to make a few more bucks... I'm hitting the 120K mark, and bringing in to have plugs changed at indy shop... just plugs.
I don't think I need anything else at this time and not paying for an inspection My last fluid change was at timing belt replacement at 90K, did water pump as well, and trans, coolant, diff and PW steering. Also replaced radiator due to small leak....This was all done at a Toyota dealer cause Lexus wanted a boat load more to do it.
Car is running like a top, and the wife does NOT want a new car. I was looking but she likes her car and does NOT want a new one ?? OK, just saved about $500 a month
Car does not sit, about 12 - 15K miles per year. 2004 with 125K. Bought in 2006 with 17K.
Trans fluid: Every ??
Diff Fluid: Every ??
Coolant: Every ??
Brake Fluid: Every ??
PW Fluid: Every ??
Cabin Filter: Every??
Coolant: Every ??
PW Fluid: Every ??
Hey, at least you are trying to read the existing material for your answers.
Vehicle maintenance and occasional repairs are usually much cheaper than new car payments.
Everyone will have different opinions on the maintenance intervals when you get outside what is noted in the Owner's Manual. My thoughts:
Transmission Fluid -- drain and fill every 30K (Toyota T-IV)
Front Transfer Case and Rear Differential -- replace every 30K (synthetic)
Coolant -- since this is long-life I would replace when doing the water pump at 90K
Power Steering Fluid -- once a year pump out the reservoir and add clean fluid (Mobil 1 ATF)
Brake Fluid -- 2 YR
Cabin Filter -- Yearly. I gently vacuum it each quarter to remove visible dirt.
https://secure.drivers.lexus.com/lex...ce-schedule.do
Brake Fluid -- 2 YR
Brake Fluid -- 2 YR
Brake Fluid -- 2 YR
Your Power steering fluid change and brake fluid change seems really excessive.
PS i would change maybe every 36-48k km (20k-30k miles)
Brake fluid, every 100k km (60k miles)
Brake Fluid -- 2 YR
Brake Fluid -- 2 YR
+1 to what RX330inFL said. I have followed the above sked, with the exception of the power steering fluid (still have the original fluid) .... 183K and our RX is running great.
BTW ChicagoRJ, there is no service interval for the power steering fluid in the Owner's Manual. Mine was never touched by the dealership and nothing was ever said about it. The first time I did this is was black when it should have been red. Am going to guess your power steering fluid is much the same, cdnewton, and probably could use some attention.
As for the brake fluid, the Owner's Manual states this should be replaced every 30K miles. As the OP put upwards of 15K miles on the RX each year that would be about every 2 years. Therefore, I would not consider that one excessive. Besides kiwi, that is EXACTLY in line with what you said. Personally, I do the brake fluid every time I have the front brakes done which has been every 40K to 45K miles. Would not push it much past that.
One of these weekends, I need to look at the plastic cover and figure out how to remove it. I looked once and broke a clip. Once I figure out how to get it off, doing the turkey baster thing is super easy.
I like RX330inFL's approach. I initially did not change PS fluid much in my vehicles and the fluid turned dark. I started doing it several times a year to get it back to red. Now do it about once a year - and use synthetic ATF.
I agree with synthetic fluid for the driveline. I have used and like RedLine and Amsoil gear oils.
Maintenance is both mileage and time sensitive. Two years on brake fluid is good - it tends to pick up moisture with time, so it is not just mileage. For coolant, I only use the Toyota brand. I rarely have issues with the cooling system when using Toyota brand coolant. I tend to replace about 60K miles though. When I use the concentrate, I dilute with distilled water.
None of this is cut and dry. Everything is a systematic approach.
Brake Fluid -- 2 YR
Brake Fluid -- 2 YR
Is changing the Front Transfer Case and Rear Differential -- replace every 30K (synthetic) - a DIY job and is there a way to tell if it has synthetic in there already and if not, is there anything special that needs to be done to switch from what may be in there to synthetic? I.e., how can you be sure you're not mixing what's in there with synthetic and is that even an issue to mix the 2 fluids?
Thanks, I'd like to get another 100k out of this car honestly, I love it that much.
I've never changed the fluid in a transfer case or differential in any car I've ever owned, then again, I usually get rid of them around 100k miles.
By not changing the gear oil in the front transfer case and rear differential you run the risk of damaging parts as the oil begins to breakdown and contaminants begin to creep into the system. If you were to change yours you would probably notice that the stuff you take out smells quite nasty. It is burned up. The cost to replace the transfer case is quite expensive and this is a very cheap preventative measure. Nothing special needs to be done to make a switch, you just do it. Mobil 1 has a 75W90 gear oil which has been mentioned before here at 2nd Generation RX. No, you never do get all the old gear oil out of the system but there is no problem in mixing the two much like there is no problem in making the switch to synthetic motor oil.
http://www.mobiloil.com/USA-English/..._75W-90LS.aspx
Check the DIY section for instruction information.
This is all about buying a daily driver and getting it to 300K with as little problems as possible.
https://www.clublexus.com/forums/rx-...ion-whine.html
