Need Tips on Looking at a used RX330
Old 03-09-14, 08:22 PM
Carver
Carver's Avatar
Congrats Hoon, beautiful car!
Old 03-10-14, 12:59 AM
tromly
tromly's Avatar
Beautiful car, you were lucky to find such a specimen! Good luck bro!
Old 03-10-14, 11:27 AM
HoOn
HoOn's Avatar
Originally Posted by RX330inFL
Looks like you may have yourself a good one there, HoOn. Anything in the records about having the timing belt and water pump replaced?
Yup, it was already replaced! I checked it in the service records.
Old 03-10-14, 11:28 AM
HoOn
HoOn's Avatar
Thank you both!
Old 03-10-14, 11:30 AM
HoOn
HoOn's Avatar
Oh, nothing major but thank God I have a month to check the car out, but when I turn I hear something on the left side of the front wheels. It sounds like something is rubbing with the springs. I'll have to see if I can find what's making the sound. It's not loud but not normal. Hmmm
Old 03-10-14, 03:25 PM
diverchris
diverchris's Avatar
Something that was not mentioned by anyone or in the Canadian owner's manual; change the PS fluid on a 60K-80k kms interval. I believe this is one of the issues for all of the faulty PS units. I know when I changed my fluid at 80k the Toyota ATF from the PS unit looked like chocolate syrup. Just food for thought. BTW your RX looks great
Old 03-11-14, 07:43 AM
HoOn
HoOn's Avatar
IU'm assuming you mean Power Steering (PS) fluid, right? I was thinking the same thing because I think my old car had a noise like that before and it was because the PS was low. I will have to check it out. Thank you for the tip!.
Old 03-11-14, 10:40 AM
RX330inFL
RX330inFL's Avatar
No, diverchris is correct. The RX does not use a standard power steering fluid. Rather, it uses a DEXRON II/III ATF there. The transmission uses Toyota T-IV.
This is all right there in your Owner's Manual:
http://drivers.lexus.com/t3Portal/do...004rx33/63.pdf
BTW, if the fluid level is low it means you may have had or do have a leak in the front steering rack.
DavidWebb
05-24-18 10:24 AM
mec75
11-29-17 04:55 AM
rapyoke
11-01-14 08:28 AM
cxjon
13
02-01-11 03:46 PM
krue3m
01-08-11 08:25 PM
Quick Reply: Need Tips on Looking at a used RX330
