Go Back   Club Lexus Forums > Lexus Model Forums > RX Models > RX - Second Generation
Sign in using an external account
Register Forgot Password?
Looking for Radiator install DYI
Thread Tools Search this Thread Display Modes
Old 01-21-14, 06:03 PM   #1
eekin80
Trader Score: (0)
Default Looking for Radiator install DYI
Gents,
New to the forum and first post. Looking for a DIY on radiator install on a 2004 rx330 japan,no tow. Hoping to help my daughter save some bucks . Can anybody in the big wide world of Club Lexus help me on this one?
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
eekin80 is offline   Reply With Quote
Old 01-21-14, 07:05 PM   #2
RX330inFL
Trader Score: (0)
Unfortunately, eekin80, no DIY has been posted for such work on a 2nd Generation RX. You might try your local library to see if they have a Chilton or Haynes repair manual.
And perhaps you could be the person who posts a writeup on this.
RX330inFL is offline   Reply With Quote
Old 01-21-14, 08:35 PM   #3
alchemist
Trader Score: (0)
alchemist's Avatar
DRAIN ENGINE COOLANT
REMOVE ENGINE UNDER COVER NO.1
REMOVE AIR CLEANER INLET NO.2
REMOVE AIR CLEANER ASSY
REMOVE AIR CLEANER BRACKET
REMOVE AIR CLEANER INLET NO.1
DISCONNECT RADIATOR HOSE INLET
DISCONNECT RADIATOR HOSE OUTLET
DISCONNECT OIL COOLER INLET TUBE NO.1
DISCONNECT OIL COOLER OUTLET TUBE NO.1
SEPARATE HOOD LOCK ASSY
REMOVE RADIATOR SUPPORT SUB-ASSY UPPER
Remove the bolt and separate the suction tube bracket.
Disconnect the horn connectors.
Remove the 5 bolts and the radiator upper support.
REMOVE FAN SHROUD
Disconnect the engine coolant reservoir hose.
Disconnect the fan motor connectors.
Remove the 4 bolts and the fan shroud.
REMOVE RADIATOR SUPPORT SUB-ASSY LH
Remove the 3 bolts and the radiator support upper LH.
Using a screwdriver, remove the cap.
Remove the 2 bolts and nut, and separate the hood lock.
REMOVE RADIATOR SUPPORT SUB-ASSY RH
Remove the 3 bolts and the radiator support upper RH.
REMOVE NO.2 RADIATOR ASSY
Remove the 4 bolts.
Lift the radiator, then remove it.
INSTALL NO.2 RADIATOR ASSY Torque: 5.0 Nm (51 kgf-cm, 44 inch lbs.)
INSTALL RADIATOR SUPPORT SUB-ASSY LH Torque: 5.0 Nm (51 kgf-cm, 44 inch lbs.)
INSTALL RADIATOR SUPPORT SUB-ASSY RH Torque: 5.0 Nm (51 kgf-cm, 44 inch lbs.)
INSTALL FAN SHROUD Torque: 13.5 Nm (138 kgf-cm, 10 ft. lbs.)
INSTALL RADIATOR SUPPORT SUB-ASSY UPPER
Install the 5 bolts and the radiator upper support. NOTICE: Secure the upper member with retaining claws of the radiator upper support. Torque: 7.8 Nm (71 kgf-cm, 62 inch lbs.)
Connect the horn connector.
Install the suction tube bracket with the bolt Torque: 9.8 Nm (100 kgf-cm, 7 ft. lbs.)
INSTALL HOOD LOCK ASSY Torque: 8.0 Nm (82 kgf-cm, 71 inch lbs.)
INSTALL AIR CLEANER INLET NO.1
INSTALL AIR CLEANER BRACKET
INSTALL AIR CLEANER ASSY
INSTALL AIR CLEANER INLET NO.2
ADJUST HOOD SUB-ASSY
ADD ENGINE COOLANT
CHECK FOR ENGINE COOLANT LEAKS
__________________
2007 GS350
2006 RX330
alchemist is offline   Reply With Quote
Old 01-22-14, 04:19 PM   #4
eekin80
Trader Score: (0)
Really nice write up. Thanks alchemist. Hoping to dig into this next weekend and will post an update.
Old 01-22-14, 07:00 PM   #5
alchemist
Trader Score: (0)
alchemist's Avatar
Take pics, where in TN are you? I'm in nashville
__________________
2007 GS350
2006 RX330
Old 01-28-14, 07:33 AM   #6
eekin80
Trader Score: (0)
Alchemist, sorry for the slow response. I'll take some pics and add them to the write up. Gonna do the thermostat too as it only makes sense since I'm already in there. Hope to dig into it this weekend. I've been in Music City for close to 30 years. Bought this RX new mainly as a daily driver for my wife and safe trainer for my kids. Wife had it part of a year and kids have had it since. Three kids, 4 years of high school and 6 years of college and it shows but everything on it still works and it runs really well. It also kept a car load of kids from getting hurt in a bad wreck in 05. Safe car, one of the best cars I've owned and my youngest still uses it.
Old 10-21-14, 01:14 PM   #7
jfmassa
Trader Score: (0)
Great write-up! Just replaced my radiator - rx330 2004. Pretty straight forward. Lower mount screw rusted and I could not get out. Two screws on each corner connect radiator to mount. Each mount has one screw through AC condenser coil (from front of car). I was able to remove bolts from 2 AC hard lines to AC condenser that allowed me to lift both units and slide bottom towards engine. This gave me direct access to radiator screws from bottom of car and I was able to remove. Sewell Lexus radiator, hoses and clamps excellent and cost-effective.
jfmassa is offline   Reply With Quote
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Leaking Radiator Dupshaw123 IS F 8 10-14-14 05:54 AM
Koyo A2062 Radiator for 1996 SC400 dhowat Performance & Maintenance 2 02-04-14 05:27 PM
Help! Head Gasket? Radiator? 1992SC300 5 speed SupraDremr Performance & Maintenance 18 08-14-12 02:51 PM
Radiator gave out! Help Kaliz2ich GS - Second Generation 7 04-13-11 12:44 PM
Which radiator cap is best? cdeeznuts IS - Second Generation 11 05-07-10 07:09 PM
Join ClubLexus
Advertising
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
