2006 highlander rims on a RX350
Hi
I want to know if a 2006 highlander 17" rims can fit my 2008 RX350,
I did a lot search and seems highlander has the same rim spec as RX350 , i.e. 17x6.5 with 35 offset, anyone have experience mount a highlander rim on your car, will it cause problem on caliper , brake at front , more specific
thanks
thanks
They will fit. Toyota and Lexus share the design, in this case Highlander and RX. Look under, they look the same.
I'd try them on the the driveway of the person you're buying them off. I've tried on 20" Venza wheels and they require a 2-3mm spacer for caliper clearance. Yet the rav4 steel wheels fit fine without spacers
harleydjce
06-16-09 02:29 AM
