Audio Help!
Old 01-10-14, 05:31 AM
MoparMan
MoparMan's Avatar
Default Audio Help!
Just replaced the front and rear speakers on the 04 rx330, and the fronts sound low, weak, and almost nothing comes out. They were replacement Kickers, adapters for the fronts, and plug-n-play harnesses for the entire system. Old speakers were absolute ****, no way for me to fix, so please help me on this!
It has the ML system
4 new kicker 4 ohm speakers, coax, rears sound great!
stock deck
Ive read somewhere, the front speakers have the amp built in, and other places there is an internal amp for all speakers and the fronts usually crap out first. I need to know which it is, and if I can fix it!
Old 01-10-14, 09:58 AM
RX330inFL
RX330inFL's Avatar
Wrong impedance. Double check the OEM you pulled for the correct value, though I believe it is 8 Ω.
https://www.clublexus.com/forums/lex...son-sound.html
Old 01-10-14, 11:05 AM
gasconguy
gasconguy's Avatar
But shouldn't 4 ohm speakers be louder, not softer? Not saying they aren't the wrong impedance, I'm sure you are right, but with half the resistance the fronts should be louder.
Old 01-10-14, 11:29 AM
RX330inFL
RX330inFL's Avatar
Without the schematics I am just guessing and thus my link to the other thread on the topic. My physics is a bit rusty. Perhaps the rating on the speakers is 2 Ω? Either way, sounded like there was an impedance problem.
Old 01-10-14, 01:10 PM
MoparMan
MoparMan's Avatar
but still, with my audio knowledge, and done the research the OE is 8 ohm, 4 ohm would sound louder and better. But my question is, why would the rears sound wonderful, and the fronts just sound odd? The old speakers did the same. but when I took them out I saw the reason for that, but putting brand new speakers in all 4 doors and having the rear two which are the same OHM as the fronts sound much better and louder than front makes no sense unless the ML system has an amp, like my truck did, and had a problem with a couple channels going bad
Old 01-10-14, 01:17 PM
RX330inFL
RX330inFL's Avatar
RX330 ML amp location discussion:
https://www.clublexus.com/forums/rx-...ion-rx330.html
Old 01-10-14, 01:19 PM
MoparMan
MoparMan's Avatar
so is there anyway to bypass the amp? or just get a new system and rewire the entire car?
Old 01-10-14, 01:38 PM
RX330inFL
RX330inFL's Avatar
Or replace with something from eBay, such as:
http://www.ebay.com/itm/LEXUS-RX330-...-/221286396031
Would at least test the one currently installed if you can.
denverdog
04-06-11 08:54 PM
John007
05-15-09 09:42 PM
SC3005SPD1
17
02-22-06 10:42 AM
CleanSC
08-25-04 09:00 AM
DJ SprinklesNJO
04-18-02 04:33 PM
Quick Reply: Audio Help!
