How to replace Fog Light Assembly?
Old 12-04-13, 12:25 PM
Rich27
Rich27's Avatar
Default How to replace Fog Light Assembly?
I checked the forums, but I couldn't find anyone replacing their fog light assembly. I had a fog light bulb burst inside the fog light and now the glass is shattered inside.
I wanted to replace the fog light assembly with a new one. I read that you have to take your bumper out or you can remove it by taking the liner from the wheel well out.
Does anyone have any experiencing in replacing the whole fog light assembly? This is for the passenger side.
Thank you!
Old 12-04-13, 01:28 PM
mandyfig
mandyfig's Avatar
You can do it from behind through the fender liner. The bumper is not hard to take off.
Old 12-04-13, 01:29 PM
mandyfig
mandyfig's Avatar
If you do a search on headlamp condensation, there will be tips in there for the removal and assembly of the front bumpers.
Good luck.
Old 12-05-13, 03:50 PM
lexsc4
lexsc4's Avatar
+1 on Fender liner. Changed out the yellowish bulb with a pair of MTEC Super Whilte 35W. Better match with the factory HID.
Old 12-05-13, 04:02 PM
jakenbake
jakenbake's Avatar
I agree with mandyfig. The bumper is not hard to take off and it is probably easier to get the fog light with the bumper off than it would be to go from underneath. Just don't try to do it if you aren't mechanically inclined.
Old 12-05-13, 04:10 PM
lexsc4
lexsc4's Avatar
No need to take off the bumper. I just turn the wheel to the opposite direction, loosen a couple of screws in the fender wheel, pull out the fender liner until you can reach in with the hand, turn and viola.
Old 12-05-13, 04:13 PM
jakenbake
jakenbake's Avatar
Lexsc4....he wants to replace the entire assembly. Not just the bulb. But on that note. I wouldn't replace the whole assembly. Just remove it and shake the glass out, the reinstall. That should a hundred or two bucks.
Old 12-05-13, 04:19 PM
lexsc4
lexsc4's Avatar
oops. I didn't realized the shattered glass part. In that case, yes you will need to remove the bumper to access the foglight assembly and shake the broken pieces out.
Heck I would not even shake out the glass. The broke pcs should not affect the light pattern. Maybe I just too lazy.
lexsc4
Old 12-06-13, 08:50 AM
Rich27
Rich27's Avatar
Thanks for the help and replies!
I checked the thread about the condensation and will take off the bumper.
Old 12-12-13, 05:32 PM
Rich27
Rich27's Avatar
Thanks for the help again. The only way to do it was to take off the bumper. I couldn't find any short cuts.
I was able to install the new fog light assembly. I plugged a bulb on for a few minutes without it being inside the actual fog light.
The reason why i did this was because I didn't want it to shatter and damage the inside of the fog light again.
Below is a picture of the damage.
Would it be safe to plug the new bulb in?
What reason would cause so much damage to the fog light assembly?
Old 12-12-13, 05:39 PM
Rich27
Rich27's Avatar
https://lh6.googleusercontent.com/-3...2013-12-12.jpg
beatle226
NX - 1st Gen (2015-2021)
03-04-19 05:58 PM
wopdud
11-05-12 12:23 AM
Haitwun
10-09-10 08:28 AM
qgoat
Lighting
03-21-07 09:45 PM
sk898
RX - 1st Gen (1999-2003)
10-26-04 10:32 AM
Quick Reply: How to replace Fog Light Assembly?
