P/N for Bank1 Sensor 1 oxygen sensor 08 RX350
Old 11-27-13, 12:28 PM
RXPhil
RXPhil's Avatar
Oh I didn’t see that there was a difference in price from Upstream to downstream. Didn’t read that far into it.
Nvm
Old 11-27-13, 08:51 PM
JoeInHNL
JoeInHNL's Avatar
Originally Posted by 5gears-IS
Great contribution to this thread!
I wonder which Denso p/n is the direct interchange to S1B1 OEM LEXUS 894670E020?
Bank 1 is the right (rear) bank. Sensor 1 is the upstream (air/fuel) sensor. I get 234-9022 as the one you need. $93.20 from Amazon with free shipping.
That is the sensor i had to replace on my RX330. On the RX330 do able without putting the car on a lift.
I used one of these to get it off:
Powerbuilt 648691 Oxygen Sensor Offset Puller : Amazon.com : Automotive Powerbuilt 648691 Oxygen Sensor Offset Puller : Amazon.com : Automotive
On the 330 there is not enough room to get the socket style tool over the sensor.
Old 12-03-13, 02:19 PM
5gears-IS
Great Deal Guru
5gears-IS's Avatar
Default ............
Great info I will install it as soon as I catch a warmer day.
Many thanks!
Old 12-07-13, 02:16 AM
Saltynutz
Saltynutz's Avatar
You get he a you pay for is all I need to say here! Why buy a lexus and cheap out about 163$ part? You want your lexus to perform like a lexus no?
Old 12-10-13, 07:16 AM
5gears-IS
Great Deal Guru
5gears-IS's Avatar
Default ..............
Don't try so hard Saltynutz.....Lexus/Toyota does not makes oxygen sensors, they are all made by DENSO.
Just because I bought a Lexus it does not mean I will be such a fool to pay dealership money for any parts.
Get Denso p/n 234-9022 and you are buying what lexus sells you at the Stealerships.
I have owned enough Toyota vehicles to know better.
Old 03-23-14, 08:47 AM
murrayjimw
murrayjimw's Avatar
Default P2195 sensor replacement
I also have the dreaded P2195 code on an '07 RX350. I'm planning on doing this myself and can't thank you guys enough for pointing me in the right direction. First I wanted to make sure this worked out for you in the B1S1 position as I just ordered this part number from Amazon (234-9022). Second I need a little help making sure I'm looking at the correct sensor under the car. If I slide under near the front passenger side tire I see two of them. One is low and easy to get to - the other is up higher and a bit more difficult to reach. I think it's the higher sensor I'm after, but if anyone has guidance on positively indentifying the S1B1 sensor before replacement I'd be most appreciative.
Thanks in advance,
Jim
Old 03-23-14, 03:56 PM
JoeInHNL
JoeInHNL's Avatar
Sensor 1 is before the catalytic converter. Sensor 2 is after the converter.
Sensor 1 is the harder of the two to reach.
Old 04-05-14, 09:23 AM
murrayjimw
murrayjimw's Avatar
Thanks!!!
Purchased these items and installed last weekend saving about $350 off the Lexus dealer installed price. Light has been off for 8 days now (was recurring daily after resets before).
Thanks to you all. I really appreciate the info and help,
Jim
Old 04-13-14, 09:16 PM
smreilly
smreilly's Avatar
I wanted to add my experience with the replacement and purchase of this part. Denso 234-9022 does not appear to be correct.
The part I removed was 894670E020 from the Bank 1 Sensor 1 Location. Based on everything I could search based only on my make and model '08 RX350 (not using the part number) the replacement part for the vehicle was 234-9022. Autozone, O'Reilly, Amazon all said that this was the correct part. So I ordered it.
Based on a side by side comparison when my part arrived, they are not the same part, although they may be interchangeable.
When I give the part number (894670E020) of the part I removed to Autozone, O'Reilly, Amazon (not the vehicle description) I was given part number for Denso 234-9042 as the replacement. A side by side comparison of these parts (894670E020 and 234-9042) is exact
If you go to the O'Reilly website you can look up each part and see the difference or similarities between the parts.
I used the 234-9042, reset the codes and have driven about 30 miles so far without the CEL coming back on.
I am hopeful that this was the fix.
If anyone is curious, I can post a picture. Also, make sure you get the offset puller as suggested previously in this thread or you will kick yourself.
Old 04-13-14, 10:42 PM
RX330inFL
RX330inFL's Avatar
When you check the Denso site you come up with part number 234-9042 when you cross reference the OE part number 894670E020.
http://densoautoparts.com/find-my-part/cross-reference
Further research seems to indicate that there are a series of these, all which will fit the RX350. All the following info is from RockAuto:
http://www.rockauto.com/catalog/moreinfo.php?pk=1607066
For 2349042 it shows: Alternate/OEM Part Number(s): 2349043, 2349045, 2349046
Fitment for 2349042 shows:
LEXUS ES300 (2002 - 2003)
LEXUS ES330 (2004 - 2006)
LEXUS RX330 (2004 - 2006)
LEXUS RX350 (2007 - 2011)
LEXUS RX400H (2006 - 2007)
TOYOTA CAMRY (2002 - 2006)
TOYOTA HIGHLANDER (2004 - 2007)
TOYOTA SIENNA (2004 - 2006)
TOYOTA SOLARA (2004 - 2008)
Please refer to catalog for application details.
Part number 2349022 does indeed look to be a different design as shown here:
http://www.rockauto.com/catalog/moreinfo.php?pk=1607178
Fitment for 2349022 shows:
LEXUS ES350 (2008 - 2011)
LEXUS RX350 (2007 - 2009)
LEXUS RX450H 2010
TOYOTA 4RUNNER 2010
TOYOTA AVALON (2008 - 2011)
TOYOTA CAMRY (2008 - 2011)
TOYOTA HIGHLANDER (2008 - 2010)
TOYOTA RAV4 (2006 - 2012)
TOYOTA SIENNA 2011
TOYOTA TACOMA (2011 - 2012)
TOYOTA VENZA (2009 - 2011)
In the end, I believe some of the confusion is based on the fact that little is noted about the country of manufacture as shown in this example from the Denso site when I looked up a 2007 RX350:
P/N for Bank1 Sensor 1 oxygen sensor 08 RX350-screen-shot-2014-04-14-at-1.40.40-am.png
Only here at Denso does this information seem to be noted and only in some instances.
Old 04-14-14, 01:38 PM
smreilly
smreilly's Avatar
I edited my last post. I used the 234-9042.
There was some discussion in one of the stores I visited about using a 234-9046. It also looks the same and the store computer claimed that the 9046 part number "superceded" the 9042.
Old 04-14-14, 02:59 PM
RX330inFL
RX330inFL's Avatar
More than likely. In what country was your RX built?
Old 04-15-14, 02:20 PM
5gears-IS
Great Deal Guru
5gears-IS's Avatar
I will like to see your pics added to this thread..............
Old 08-28-14, 01:50 PM
5gears-IS
Great Deal Guru
5gears-IS's Avatar
Default .....................
Reviving this thread to add a cross reference chart for all Oxygen sensors AC Delco / Denso
http://www.autopartsunrise.com/index...-Denso.sunrise
Enjoy!!
Old 02-09-16, 08:57 AM
dmanwi
dmanwi's Avatar
I am getting code 2195 at 106k miles. I looked and the previous owner replaced B1S1 at 86K in April of 2014 at a dealership. I am wondering if that is too soon for the sensor to go bad and if there is something else I should be checking?
Thanks.
Quick Reply: P/N for Bank1 Sensor 1 oxygen sensor 08 RX350
