Annoying "rattle"
Old 11-07-13, 05:04 PM
SIB
SIB's Avatar
Default Annoying "rattle"
i have a 2007 350 rx that has a "rattle" I think is coming from the cargo cover attachment. May get rid of the car because Lexus can't seem to determine if that is the cause of the rattle or can't repair it. i removed the cover and the rattle still there. think it is the plastic connector. They removed the crossbar on top but rattle still there. any similar problems. Nice car and an annoying rattle.
Old 11-07-13, 05:19 PM
Carver
Carver's Avatar
When does the rattle manifest? All speeds? Over bumps? High speeds? There's a peice of cladding under the car that is famous for causing "rattles" seemingly from everywhere.. It's on the driver''s side and the leading edge loses it's adhesive and flaps around.
Old 11-07-13, 05:51 PM
RX330inFL
RX330inFL's Avatar
Print out the attached and show it to your service writer. Is what Carver is describing.
L-SB-0028-08.pdf
Old 11-07-13, 07:39 PM
Rainbird
Rainbird's Avatar
There is also a known problem with a rear rattle that manifest itself only at low speeds. There is a TSIB #NV5016 (Tonneau Cover, Latch Rattle) on this issue. My 2007 was repaired at no cost.
Old 11-07-13, 07:57 PM
Rainbird
Rainbird's Avatar
I want to clarify something. This rattle has nothing to do with the Tonneau Cover itself. Instead the problem is with the latches that grab the cover when you close it at the rear hatch. You can in fact determine if this is the problem by simply leaving the tonneau cover open and pushing the two latches forward until they lock in a position away from the rear hatch. The problem is those spring loaded latches rattling against the rear hatch. Lexus repairs this by replacing several plastic panels in the rear hatch.
Old 11-07-13, 08:39 PM
Rainbird
Rainbird's Avatar
Here is the PDF file on the TSB
File Type: pdf
Old 11-11-13, 07:19 AM
SIB
SIB's Avatar
Can't believe the cover latch rattle pdf..and the other possibilities. I have printed it all off and will take it all to my Greensboro nc Lexus dealer. Thank you. Thank you.
Old 12-15-13, 02:43 PM
lex_rx
lex_rx's Avatar
SIB, any update on this?
donkiboy
01-21-19 11:06 AM
sejinro
04-15-12 07:35 AM
bernierb
ES - 5th Gen (2007-2012)
13
03-28-12 06:42 AM
fredw1
RX - 3rd Gen (2010-2015)
12-06-10 01:13 PM
Quick Reply: Annoying "rattle"
