Led drl
Led drl
I installed a set of LED in my high beam slot to use as LED DRL. I know that I'd loose the brightness of the high beams but wanted the color / modernness of the LEDs. I installed them bit they did not light up as DRL only when I turn on the high beams. I though it was a resistor issue so I added a set - still no lights during the day. Any ideas? Anyone using these successfully?
Here is what you need
Be sure you set it up just like the instructions instruct you to. They will work and they look good. This is for 9005 bulbs (or LED substitutes) and the headlights will not get brighter when you hit the bright switch on them. But they do make nice looking DRLs.
hmm, so I bought the wrong harness. I did not know they were different. Did some searching. Is this the correct one?
http://www.ebay.com/itm/9005-HB3-LED-Light-Xenon-headlight-No-Error-Load-Resistor-Wiring-Harness-Adapter-/121173824259?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c3685d303&vxp=mtr
Buggeroff6
12-30-15 07:17 AM
