Front control arm bush
Old 09-25-13, 08:22 AM
aeroelasti
aeroelasti's Avatar
Default Front control arm bush
Hi,
Anyone has the part numbers for the OEM rear bushes of the front control arm/wishbone?
Is it cheaper to buy a whole new wishbone with bushes inserted compare to the labour of removing the olf one and press it back using hydraulic press?
Thanks
Old 09-25-13, 08:30 AM
RXPhil
RXPhil's Avatar
I just ordered brand new ones from rockauto.com. They're $60 each with a brand new ball joint bolted to them. For $120 you can't go wrong.
Old 09-25-13, 09:02 AM
aeroelasti
aeroelasti's Avatar
Thanks.
I dont supposed it is crucial to have OEM bush for this? Anyone use updgraded poly bush or something?
Old 09-25-13, 02:46 PM
RXPhil
RXPhil's Avatar
An RX is made for comfort. Poly bushings are going to make the ride worse.
Old 09-26-13, 03:12 AM
aeroelasti
aeroelasti's Avatar
Tha.. Will go for some aftermarket complete arm then.
Old 09-27-13, 01:25 AM
RuninRoach
RuninRoach's Avatar
anyone have a clue if the RX330 US version arm and bushing fit the Euro/World RX300. Both are second generation RX, but the euro/world has the 1MZ engine.
Old 10-02-13, 04:51 AM
aeroelasti
aeroelasti's Avatar
Spoke to a Lexus dealer (I am based in the UK), the part numbers are 48068-48020 & 48069-48020.
The OEM Toyota part is expensive, nearly £200 per arm. They dont sell the bush separately, which is what I want to replace. After market part can be as low as £60 per arm, a huge different.
Dont know what to do now. Might be cheaper if I ship some in from the States.
Old 10-02-13, 05:44 AM
RX330inFL
RX330inFL's Avatar
Not sure if there are now updated part numbers or if there is a difference. They come up at Sewell Lexus of Dallas as 480690E010 and 480680E020.
http://lexus.sewellparts.com/oem-cat...X330-2004.html
With international shipping approaching $US300 from that source you might be best looking and purchasing local. What brand aftermarket parts are available to you? As an example:
http://www.rockauto.com/catalog/more...680&cc=1421312
Old 10-02-13, 06:47 AM
aeroelasti
aeroelasti's Avatar
Thanks for the links. Here in the UK we only have RX300, not RX330, not sure if that would make a different. Only Lexus dealer can tell I suppose. m
I once imported a rear wheel bearing from States and with postage it is cheaper than buying locally. But there is a risk, if the parts don't fit then I wont be able to send them back. Or I will but it will cost a fortune.
I read on other forum that the RX control arm and the Camry control arm are interchangeable BUT this is for the first generation RX, nobody say anything about the 2nd generation yet.
Has the day of changing the bush only gone now? I used to be able to change these bush without changing the whole arm on my other car. The Lexus dealer told me that they don't do the bush separately...
Old 10-02-13, 07:26 AM
RX330inFL
RX330inFL's Avatar
If looking at Toyota parts I might think the UK RAV4 might be a better point of reference though that is just a guess.
No, bushings are still available. You just need to spend more time looking for them or perhaps you may not like the sources they are available. There is also the case of what may not be available in the UK may be available elsewhere in the Eurozone. Perhaps you can contact these folks to ask about the viability of their product.
http://www.ebay.co.uk/itm/FRONT-LOWE...item3a85559e30
Old 10-02-13, 07:32 AM
aeroelasti
aeroelasti's Avatar
Thanks for all your help, appreciate it. Will drop them an email...
Old 10-02-13, 07:49 AM
RX330inFL
RX330inFL's Avatar
Their phone number was listed there as well near the bottom of the description.
Old 10-02-13, 08:08 AM
aeroelasti
aeroelasti's Avatar
Found a cheap aftermarket brand on Amazon, FEBEST. anyone heard about this brand before? I think its a German firm.
Old 10-03-13, 06:07 AM
aeroelasti
aeroelasti's Avatar
Found another brand, DORMAN, anyone can shed any light on this?
Old 10-03-13, 06:36 AM
RX330inFL
RX330inFL's Avatar
Both brands are international. Dorman is more well known though Febest does have an office here in FL. Of the two I would go with Dorman.
http://www.rockauto.com/catalog/more...685&cc=1421312
The Critic
01-30-19 09:36 AM
RXGS
Suspension and Brakes
15
11-21-15 05:52 PM
texan_176
SC400 / 300 Classifieds
10-19-10 04:27 PM
aEO 37
05-02-10 05:48 AM
96ls400ky
06-04-08 07:15 PM
Quick Reply: Front control arm bush
