Toyota delaer wants $350 for timing belt change, or add $400 for water pump???
So, does my 2006 RX330 with 100K not require the same level of work to get to the timing belt as most other cars do? Both the Toyota and Lexus dealers said that the water pump does not need to be replaced when the timing belt is changed, but can simply be looked at for signs of failure.
I always heard that the labor to get to the timing belt is so involved that it only makes sense to replace the water pump at the same time, since you are already there, thereby avoiding to have to repeat the same labor requirments at a later time when the water pump goes.
If the Toyota shop is quoting me $350 to switch out the timing belt, should I just do that, and then worry about the water pump later, especially since they want $400 more to do this on top of the timing belt?
Any thoughts?
Thanks!
Any thoughts?
Thanks!
But I'm also surprised to hear of "only" $350 for the belt.
I had a look at the DIY posts, and I was considering to make it myself when it will be due on my RX.
But at $350, I think I wouldn't bother.
Interested to hear other views on the pump, though.
If that's the quotation they gave you under the assumption of replacing it while changing also the belt, I would think that most of those $400 (if not all) are the part cost - which is hard to reduce also with a DIY job...
No, it sounded like the $400 for the water pump job would be the same price with or without the timing belt job. And btw, I just checked my notes, and it is actually $310 for the timing belt job alone, not $350.
What if you offer to supply them with the water pump part(s)? Ask them how much in labor they'd charge to install it while doing the timing belt.
Hope the new water pump is as reliable as the original one that works fine even after 100K miles.
Sent from an Android device using IB AutoGroup forum reader.
When I asked about this repair of the local Lexus dealers some time in the past I was told that they only inspect the water pump and that in their opinion the water pump was usually good until the second time the timing belt needed to be replaced or about 180K miles.
However, it has been common practice over the years to replace the water pump, seals, etc. at the time you replace the timing belt as you already had everything apart and it saved you the labor of having to do the same exact thing again to take the water pump back off.
The OP says the work would be done by a Lexus or Toyota dealership. They simply will not install a part brought in by the customer (aftermarket or OEM).
I am at 100k and was also considering the water pump. I decided not to do it because it is low risk. When they fail they slowly leak pink fluid from the weep hole. In the old days water pumps were under more pressure from an accessory belt that also ran the AC. Our water pump is driven by the timing belt which is not nearly under the same tension. We also have better lubricants in our coolant.
http://lexus.sewellparts.com/oem-cat...X330-2006.html
Even with a healthy discount when you add shipping it is going to cost you a bit. Perhaps you could find a third-party unit on eBay. Plus, don't forget about the gasket. And just because you can purchase at that price doesn't mean the shop is using that source. Many get their parts from a set list of distribution and dealer part system warehouses. Then they will want to add their mark up on the price of the part as well. After all, you will want some warranty on that repair job and the shop needs to be comfortable with the quality of the parts used. They do not have to accept any work should you walk in with parts you want installed -- it is their shop.
Next, when a shop quotes you for a repair job they use the book (now a computer and software system) which indicates the labor for the job. This value is most always much more than the amount of time it actually takes for the job. Regardless of how much time it takes, you get charged the book rate for the job. Most shops operate this way. While you have to take the water pump off to get to the timing belt, this particular shop is probably charging the timing belt and water pump as two separate jobs. Meaning that whatever the book rate is for each job is what is being charge. More profit for them and an industry norm.
A more expensively sourced part with a labor charge by the book easily explains why the water pump quote came in at $400.
Now of course most everything is negotiable. Customers need to understand the work being performed, what they are being charged, and to get multiple quotes if possible for any necessary repairs. If you explain that you know they are double charging for most of the labor perhaps they will give you a break on the price of the repair.
Well, first of all while you might be able to purchase an OEM water pump for $60 (though I am unsure where) the retail price of said part is $176 according to the Sewell web site:
I do not purchase from Sewell. They are still pricey. And yes, you can get an Aisin pump on ebay or Rock Auto with gaskets for 60 shipped unless you live in Uzbekistan.
Thanks all for your advice. It makes perfect sense for them to be charging the water pump as it is a separate job now, as yes a $400 water pump should be made of gold.... I will contact an independent shop in the area to see what they would want to do the job.It only makes sense that if old parts have to be removed for the timing belt job, to just charge me for the parts, and no additional labor for putting it back together.
Understood. And I have done this myself on multiple cars and have had it done for me as well so I am familiar with the process as well as how mechanics and shops charge. I have never been charged for water pump labor (even at Lexus dealer) as long as you are getting the belt changed at the same time. Simply put, he needs to search around for a reliable mechanic to do the work.
http://lexus.sewellparts.com/accesso...2006/4638.html
While you have been lucky to not have experienced a dealer charging in such a manner the forums here are full of folks who have had exactly this happen. Quotes for such work posted here at CL have exceeded $1200-$1400 if not more, such as:
https://www.clublexus.com/forums/rx-...ater-pump.html
Agreed that the OP needs to shop this around, ask questions and get to know exactly what work is being performed and at what price.
Get everything replaced associated with the t-belt, like water pump, gasket, tensioners, etc. It only makes sense to have all that stuff replaced while in there to get the t-belt done. Why have a new belt and then a pump with over 100k miles?
My local Toyo dealer just quoted me $880 for new timing belt, water pump, coolant, mount and balance 4 tires (tires purchased separate), and wheel alignment. 2004 RX330 with 86,000 miles.
