Go Back   Club Lexus Forums > Lexus Model Forums > RX Models > RX - Second Generation
Sign in using an external account
Register Forgot Password?
removal and installation 2005 Lexus RX330 driver side Door Trim Panel diagram
Thread Tools Search this Thread Display Modes
Old 09-07-13, 11:27 AM   #1
frankeysd
Trader Score: (0)
Default removal and installation 2005 Lexus RX330 driver side Door Trim Panel diagram
Any Exploded view of Removal and Installation 2005 Lexus RX330 driver side Door Trim Panel?
Appreciate very much!!!
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
removal and installation 2005 Lexus RX330 driver side Door Trim Panel diagram-kgrhqjhjeufe2hmwii1brdpj-voqq-60_1.jpg
frankeysd is offline   Reply With Quote
Old 09-08-13, 05:29 AM   #2
mandyfig
Trader Score: (0)
mandyfig's Avatar
The panel is normally held by clips and a few bolts.
Other than removing the bolts, should be straightforward. You have to have the right tools to be able to yank out the panel.
Do not know exact locations of the clips, with the proper tool you should be able to pry the sides and see if you can locate the clips and just yank away.
Like this:
removal and installation 2005 Lexus RX330 driver side Door Trim Panel diagram-pry.jpg
__________________
SC430 WGC-Ecru/RX330 Bamboo Pearl-Gray/IS350 Black Onyx-Gray
mandyfig is offline   Reply With Quote
Old 09-09-13, 06:56 AM   #3
frankeysd
Trader Score: (0)
Like this:
where can you get this tools and how much? the reason I'm doing it is because it's only my right, front speakers are working. I'm curious to find out what's going on behind those panels.
Thanks!
Old 09-09-13, 07:16 AM   #4
RX330inFL
Trader Score: (0)
Quote:
Thanks!
The tools are available most anywhere parts are sold.
Wilmar W80648 Composite Trim Removal Tool Set : Amazon.com : Automotive Wilmar W80648 Composite Trim Removal Tool Set : Amazon.com : Automotive
RX330inFL is offline   Reply With Quote
Old 09-14-13, 01:33 PM   #5
frankeysd
Trader Score: (0)
Default Speakers Problem with 2005 Lexus RX330
No sound in rear speakers. have adjusted all settings, balance, fader, mid,base,treble. Everything varies but no sound in rear - either speaker.
Anyone experienced this problem?
Cheers!
Old 09-14-13, 08:45 PM   #6
Denvermgb
Trader Score: (0)
If all of those speakers went out at the same time, perhaps a plug with numerous speaker connections became loose. That's where I would start.
Denvermgb is offline   Reply With Quote
Old 09-16-13, 09:36 AM   #7
dcdyd
Trader Score: (0)
I removed door panel several times. I just use hand carefully pull the panel after screws are removed. No special is really necessary.
dcdyd is offline   Reply With Quote
Old 11-15-13, 10:10 AM   #8
fulflaps
Trader Score: (0)
Where are the screws located?
Thanks
fulflaps is offline   Reply With Quote
Old 11-15-13, 10:13 AM   #9
fulflaps
Trader Score: (0)
Default 2005 rx 330 door panel removal for spkr replacement
Just found out I have a blown passenger door speaker.
Thanks
Old 12-28-13, 09:47 AM   #10
patesrwe
Trader Score: (0)
Default remove rx330 door panel
I found this on this forum and it was EXTREMELY helpfule
https://docs.google.com/file/d/1RBAn...generati&hl=en
patesrwe is offline   Reply With Quote
Old 12-28-13, 12:35 PM   #11
RX330inFL
Trader Score: (0)
Document unavailable. You can attach to a post here at CL if you have the file as long as it is not copyrighted material.
Old 01-02-14, 11:55 AM   #12
lexusfan05
Trader Score: (0)
Here's the document. I saved it because it's so useful.
lexusfan05 is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Left Rear Door Lock Chatter RX330 2005 afterburne RX - First Generation 0 08-18-14 07:51 PM
Replacing driver's side door handle sr20bet IS F 3 06-11-14 05:55 AM
2000 RX 300 plastic ext driveside panel removal CharlieH RX - First Generation 3 05-04-14 01:44 PM
04 RX 330 Door panel removal ? rtpatter RX - Second Generation 10 07-28-10 01:23 PM
RX330 Aluminum Door Sills DaveJ RX - Second Generation 2 08-19-06 11:41 AM
Tags
05, 330, accessories, door, driver, front, install, lexus, panel, passenger, rear, removal, remove, rs, rx330, side, speaker
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
