Swapped Back-up Lights for LEDs (**PICS**)
Old 01-28-14, 02:01 PM
Meadow
Meadow's Avatar
Originally Posted by JProdun
Used pliers, worked like magic! Thank you!
I also bought the 921s from vleds, did yours fit back in the housing alright? Mine seem be a bit too big, did fit though...
Mine were a very tight fit also, but they did fit.
Old 01-28-14, 03:34 PM
alchemist
alchemist's Avatar
it was tight but yes they did fit. Then again, the bulbs that came out were tight too
Old 01-28-14, 06:16 PM
TaninAuto
Sponsor
CL Vendor - Starter
TaninAuto's Avatar
We have nearly every LED for the interior and exterior of the RX. If not, we can special order it. We have some 921 LED's on order and I promise you we can offer a significant savings over vleds and we are a supporting vendor!
Let us know what you need! Dome lights, door lights, gauge cluster lighting, etc.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
Old 01-28-14, 07:40 PM
rtbrjason
rtbrjason's Avatar
Can you quote a set of reverse bulbs for an 04 330rx?
Old 01-28-14, 09:08 PM
TaninAuto
Sponsor
CL Vendor - Starter
TaninAuto's Avatar
Looks like that year uses a 7440 bulb. We have the 7440 LED for $3.99 each and they can be ordered here:
http://www.taninautoelectronix.com/T...-p/t20_led.htm
__________________
262-456-4147
Old 01-29-14, 08:42 AM
redbaron
redbaron's Avatar
Im looking for some bright backup bulbs and the front and rear dome light led bulbs in white (not yellowish or blueish) for the 2006 RX400h. Can you give a price quote and are they plug and play?
Old 01-29-14, 08:59 AM
TaninAuto
Sponsor
CL Vendor - Starter
TaninAuto's Avatar
This is a good site to find out what your car takes. The problem is that it's not always accurate or complete
http://www.sylvania.com/en-us/applic...s/lrgmain.aspx
The reverse lights I will have in a couple weeks, they are 921s. The dome light is showing just one 31mm festoon. It is white. I would think you have more than one dome light in there, maybe a map light or two.
I would pop off the dome cover and verify what you have and how many you need. We have the festoon in stock, $2.99.
Old 01-29-14, 10:04 AM
RX330inFL
RX330inFL's Avatar
Would be nice to see additional data about the products on your site. Not only do I we care to see color temperature and price, we also want to see the lumen output. If I am paying to replace a set of 194 bulbs, for example, I want to know how much brighter compared to a standard bulb they would be.
Old 01-29-14, 11:06 AM
TaninAuto
Sponsor
CL Vendor - Starter
TaninAuto's Avatar
I understand what you are saying and will implement some changes when I get my next order of LEDs to have a comparison.
I see what all the other sites are doing and to me, it is overly complicated to buyers. Brightness ranges, 5-10 different choices of one LED, difference in light projection, Light outputting straight out vs 180 vs 360 degree, and all at 10 different price points.
It's all great, but as a buyer I want one bulb that works perfect for the application I need it in at a great price. I want one LED that works perfectly in my side indicators.
Our 168 LED's are perfect replacements for OEM lighting. They will not be obnoxiously over-bright and the light projection will be correct to the application. I've attached a photo below of the type of product you would be receiving.
__________________
262-456-4147
Old 01-29-14, 03:15 PM
RX330inFL
RX330inFL's Avatar
Does not need to be that complicated, Jason. For example...
A standard Sylvania 194LL bulb is easily found to have an output of 25 lumens with a color temperature of 2800K and with a given set of dimensions when searching a local B&M store:
http://shop.advanceautoparts.com/web...rchTerm=194+ll
A similar Sylvania LED replacement bulb is easily found to output 55 lumens with a color temperature of 6000K, again with dimensions provided:
http://shop.advanceautoparts.com/web...led#fragment-2
Now, while I agree that this LED may not be the appropriate bulb for a particular task due to fitment or color temperature it would be helpful to have more details available for those with more than casual knowledge of the topic. This would be a way for us to determine the suitability of your products on our projects without having to just take you word for it. Otherwise, you are no different than some shop selling on eBay.
john62395
john62395's Avatar
Those look sick! I know what I am doing next. Most likely will be doing the license plate light too. Very cool!
Old 01-29-14, 03:38 PM
TaninAuto
Sponsor
CL Vendor - Starter
TaninAuto's Avatar
Understood, I will update my LED's with the appropriate lumen information. My colored 168 LED's are also in the 50-60 lumen range.
Old 02-10-14, 02:12 PM
TaninAuto
Sponsor
CL Vendor - Starter
TaninAuto's Avatar
921 Super Bright LED's are in stock and ready to ship
https://www.taninautoelectronix.com/...tCode=921_cree
__________________
262-456-4147
Old 02-10-14, 02:31 PM
Highway33
Highway33's Avatar
Would like to get the Reverse Bulbs for my 07 RX350. Also the license plate lights as well. Can you please tell me how to find them on your site TaninAuto
Old 02-10-14, 02:34 PM
TaninAuto
Sponsor
CL Vendor - Starter
TaninAuto's Avatar
You type in the part number of the bulb in the search bar on top. If nothing comes up send us a message.
__________________
262-456-4147
Quick Reply: Swapped Back-up Lights for LEDs (**PICS**)
