Other OEM 20" Wheels for RX350
Hi all,
I saw an older post where ppl discussed possibly getting OEM FX35 wheels (20x8 40mm offset) might fit on a RX350. Is it true that a FX35 20" wheels will fit?
Please advise...
And if you guys have any other OEM 20" wheels that might work and that might look good please advise. I would really appreciate any suggestions.
Thanks all!
Please advise...
Thanks all!
Hi all,
Please advise...
Thanks all!
Please advise...
Thanks all!
Sorry, I'm still trying to figure out this whole offset thing. Please correct me if I'm wrong, the higher the offset the more clearance for my brakes, right? If so, +40 offset would clear my breaks but I would then have to worry about rubbing on the struts/inner wall of my car, right?
Thanks again...
It's the other way around. Higher will hit the calipers plus other things and lower clears the caliper. The lower you go, the more the wheel sticks out.
Damn, I was starting to like those FX35 rims too.
Any other suggestions, guys? Any other good looking OEM wheels that may look good on a RX350?
4th Gen RX wheels on 2nd Gen RX
I just installed wheels from a 4th Gen Lexus RX onto my 2007 Lexus RX350. I had to go with a 245/45/20 tire size to match my stock diameter. These wheels are a little wider than the stock wheels.
4th Gen RX wheels with 245/45/20 tires.
Stock wheels
Stock wheels
Wow, nice, sitting flush. Why Kumho?
8'' wide w/ a 35mm offset. I went w/ TSW's 8.5''x18 w/ a 20mm offset. The rears are flush w/ the front just a tad out thanx to the wider front track then the rears...
I believe I uploaded a couple pix.
Brewdog
RX - 3rd Gen (2010-2015)
06-18-11 03:43 PM
