Floorboard wet/standing water
Old 06-17-13, 06:41 AM
25Ellie
25Ellie's Avatar
Default Floorboard wet/standing water
The driver's side floorboard is soaked with water after a heavy rain. We isolated the leak to be from the moon roof drain on the front driver's side, which is draining into the car somewhere from behind the panel where the fuses are located under the dash on the lower left side panel driver's side. Can anyone explain how to access the drain hose from this location to see if it has come detached somewhere. Looks like to much water to be a simple leak. We have already run trimmer line through drain hose to check for clogs and poured colored water through to check where water is draining. Any help appreciated.
Old 06-17-13, 08:15 AM
Rainbird
Rainbird's Avatar
Welcome to Club Lexus. This leak problem has been previously discussed. Use the search this forum function to search by keyword. Here are three threads of this issue:
https://www.clublexus.com/forums/rx-...roof-leak.html
https://www.clublexus.com/forums/rx-...with-leak.html
https://www.clublexus.com/forums/rx-...some-help.html
Old 06-17-13, 08:31 AM
alchemist
alchemist's Avatar
I believe you will need to unbolt the side rocker. Lexus had to this to access my rear drain tubes beneath the car. I am assuming it's the same for the fronts.
DREED2017
05-01-17 12:59 PM
magnoman
10-23-12 11:59 AM
magnoman
10-21-12 03:06 PM
dcz
10-16-07 07:07 AM
Quick Reply: Floorboard wet/standing water
