Timing Belt 2004 RX330 Any Thoughts?
Old 04-01-13, 11:11 AM
  #31
gusar
gusar's Avatar
Originally Posted by fancyjean
Reading through your messages about the timing belt. I have a 2010 that is at 70k so I am planning. Can I ask, do you have a great mechanic? I think I am not too far from you and I am out of luck on mechanics. And my Lexus dealership has changed hands and I no longer get good service by them, or straight talk. Let me know if you have any local tips on service. Thanks.
This guy (Harry) is certified and good:
http://orendaautorepair.com/
Old 04-01-13, 08:46 PM
  #32
HtownBlue
HtownBlue's Avatar
I'm not sure if that is OEM or not, but OEM is usually stated somewhere readily readable.
Most OEM stuff will work fine, but I think the Toyota pumps are not much more expensive from Sewell etc.
Old 04-02-13, 01:42 AM
  #33
CJ7Hokie
CJ7Hokie's Avatar
Good call, however, I have never tackled a timing belt, so unless and independent shop will let me bring in the parts, my local Toyota shop price's are so much higher than Sewell's.
Old 04-02-13, 06:48 AM
  #34
R3Wood
R3Wood's Avatar
Local guy in town wants 1/3 of what dealer wants. He said not OEM parts but come as a kit? With belts, pump and bearings.
Old 04-02-13, 09:56 AM
  #35
alchemist
alchemist's Avatar
just get oem parts off ebay or through Sewell and take them to him.
Old 04-02-13, 11:17 AM
  #36
hypervish
hypervish's Avatar
Please use only OEM parts.
Old 04-03-13, 03:38 AM
  #37
R3Wood
R3Wood's Avatar
I have done 5 of these jobs. 3 at around 90 K, 1 around 110, and 1 at 122,000 miles.
hold up
ALL THE BELTS LOOKED EXTREMELY GOOD. There was little to no wear on the belts what so ever.
120K is not even a stretch for the life of these belts. I did mine at 90K, and I now have nearly 200K on mine, and won't even touch it until 210K or maybe 220K. The factory belts are extremely good and hold up very well.
How about the drive belt. Same mileage for replacing that also?
Old 04-03-13, 03:47 AM
  #38
hypervish
hypervish's Avatar
You should replace the drive belts at the same time. They are cheap, and they have to be removed anyways to do the timing belt job.
Old 04-03-13, 04:13 AM
  #39
R3Wood
R3Wood's Avatar
Thanks!
Just had rear brakes/rotors, air/cabin filter, Mobil 1 Oil Change, alignment checked, yesterday at 74,916. Re-nitroed the new Continental PureContacts. We should be ready for summer .
This thread helped a bunch for making my decision to wait on the timing belt until 90K.
Thanks,
Rich
Old 04-03-13, 05:58 AM
  #40
chrisxmoa
chrisxmoa's Avatar
Default cost of job
hello,
further to this convo, im wondering, what would be the average cost of having
"timing belt, water pump, tensioner, cam seals, crank seals, both idler pulleys"
done at a non lexus shop ? my mechanic quoted me at $ 850
Old 04-03-13, 08:54 AM
  #41
alchemist
alchemist's Avatar
Originally Posted by chrisxmoa
hello,
that is about right in my opinion for all of those parts which is basically everything if you also include drive belts. Lexus dealer will be ~$1200
Old 04-03-13, 09:18 AM
  #42
RX330inFL
RX330inFL's Avatar
hello,
Depends on the parts being used. Be sure to ask what brand parts. If they are not OEM (Toyota/Lexus) then this could be a bit high. The accessory belts should be changed at this time as well.
Some independent shops have access to purchase their parts through WorldPac. If so, then they are getting the same parts as the dealerships as they supply those as well.
Old 04-03-13, 09:48 AM
  #43
01LEXPL
01LEXPL's Avatar
If not OEM it is probably a Gates timing belt kit - just as good in my opinion and what I have on my ES300 [was done well before i knew about rockauto]
I personally would [and have] buy the Aisin kit from rockauto.com, add the hydraulic tensioner [for some reason sold separately] and buy some belts [since you're in there, might as well change the PS/alternator belts]
For this job too, my mechanic had to remove the front valve cover, so if you really want, get that kit too, if you chose not to re-use the old gasket.
Old 04-03-13, 03:35 PM
  #44
R3Wood
R3Wood's Avatar
Thanks. Good info.
lou95gts
06-26-20 04:43 PM
Nathan1
05-22-20 04:08 PM
jonas's RX
10-31-15 06:12 PM
RMalik
Maintenance
02-13-15 03:54 PM
lexuslass
12-07-11 05:22 PM
Quick Reply: Timing Belt 2004 RX330 Any Thoughts?
