Battery recommendations for 350 please
Old 03-25-13, 11:05 AM
fancyjean
fancyjean's Avatar
Question Battery recommendations for 350 please
Hi, Have replaced my 300 w a RX350. 70k miles on battery and I left the hatchback open all night. Dead battery, called AAA. Jump started and tested. Said I had a dead cell and needed a new battery. Recommendations? Sears, Walmart, Lexus, whatever experts think please comment. AND please tell me if there are any gotcha's heard rumors of saving memory, secondary problems with NAV etc. Thanks so much.
Thanks much. Got the Walmart and had it installed. Called Lexus and got a quote for 250 to have a Lexus battery installed by them. So thought a Walmart install would be OK based on everyone's experience. Expect the battery will be fine, did lose all destinations in my NAV, and preferences on all electronics etc. So, I guess Stevek1 was right and that was not done. I asked if they could do a save of what was in memory and they said that would not be a problem. But I am resetting all things, so I will know next time to not let them dismiss this but tell me exactly what they are doing to save my presets. Thanks all.
Old 03-25-13, 11:50 AM
LEXRX04
LEXRX04's Avatar
I would stick with name brand batteries...that is just my opinion. There are a ton out there...but a Lexus battery should be right around 125.00 or so. Your looking around at least 100.00...but as long as you get a battery that matches up to factory specs or better you should be fine.
Old 03-25-13, 01:11 PM
stevek1
stevek1's Avatar
and you need to jump power to your cables while replacing the battery or you will lose a lot of presets.
Old 03-25-13, 02:29 PM
dcdyd
dcdyd's Avatar
I brought one for 08 from Costco and it works well. There are not much difference among batteries out there and if you look at the recommendations from 'Consumer Reports', you can find one which is better than average.
Old 03-25-13, 03:10 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
Batteries are batteries....unless you have special needs (e.g. sound system) otherwise go with the ones with better warranty.
I've been using the one from Costco for my cars and have no problem at all.
Old 03-25-13, 03:13 PM
mandyfig
mandyfig's Avatar
Costco ++ Can not go wrong.
Old 03-26-13, 08:31 PM
mcfancy
mcfancy's Avatar
Actually CR gives high ratings to Walmart batteries. I've bought 2 (incl for my rx330) and they work great incl thru the winters and at a reasonable price. Ps I bought a Costco battery several yrs ago and only got 3yrs out of it....never again
Old 03-26-13, 08:36 PM
HtownBlue
HtownBlue's Avatar
CR just trated teh Duralast GOLD series as their best tested for 2012.
Most batteries will last 4-6 years. The warmer climates are harder on batteries and 4 years is not unheard of though 5 is about average in warmer climates. Colder ones can get 6 or 7 years usually.
Old 03-26-13, 08:51 PM
Dinomon
Dinomon's Avatar
I got my RX330 battery from Sams, they were around $85 after tax compare to $150 at Lexus.
I think I got a really good deal at Sams vs Lexus for similar or same quality battery.
Old 03-27-13, 05:53 AM
thomas1
thomas1's Avatar
The Sams club batteries are great, plus 1 on that...and no proration for first three years.....
Old 03-27-13, 07:47 AM
dcdyd
dcdyd's Avatar
Costco has 72 or 100 month warranty now (I don't exactly remember the number of month but is really long). So if the battery fails in 3 years you can get refund.
Old 03-27-13, 08:40 AM
mandyfig
mandyfig's Avatar
The Costco replacement is a bit taller, I had to use some shims on the tie down, can not beat the price and warranty. The specs are greater than OEM.
Old 03-27-13, 08:54 AM
offroad200
offroad200's Avatar
I've always had really good luck with Interstate batteries in my cars over the years.
Old 03-27-13, 09:48 AM
MerlinT
MerlinT's Avatar
Replaced mine last year, bought it from Costco and it works well !
Old 03-27-13, 01:39 PM
RX3302004
RX3302004's Avatar
I think Interstate and Optima are better than most. However on all of my vehicles I replace the battery after 3 years of use no matter what. I might pay a bit more in the long run but I'm never stranded and a battery from the Toyota dealer has been under $100.
Quick Reply: Battery recommendations for 350 please
