rusty rear lift gate pistons
My 2004 RX 330 has rear lift gate pistons which have the outer piston cylinder tips covered with rust and pealing paint. I expect the pistons would probably seize in the next year or two as salted roads are common in Western New York winters. Is this an easy aftermarket replacement procedure and where can the pistons be purchased.
I would expect the job would be considerably more expensive if done by a dealer.
yep, they should be available aftermarket, but i would check with the dealer, sometimes the little bit extra money is worth it,
just dont forget to support your hatch with some wood or a pole, not a person. hatches are alot heavier than you might think
They are easy to replace and the shocks can be found in a typical Auto BM store.
Common, and very easy to replace. Has been discussed several times previous.
http://www.autopartsbylou.com/lift-s...e=mmy&x=11&y=8
