04 RX 330 Radio Not Working
Old 01-12-13, 12:26 PM
PWR
PWR's Avatar
Default 04 RX 330 Radio Not Working
my radio/cd player hasn't worked for 5 months. 3 weeks ago, the radio came on and worked for about 45 minutes. Since then, i occasionally hear a static noise and the radio comes on for a few minutes then nothing again for several days.
any thoughts would be appreciated.
Old 01-12-13, 12:58 PM
RX330inFL
RX330inFL's Avatar
Could be almost anywhere in the system from the headend to the amp to the wiring. There are not enough details in your post to make a positive determination. You need to find a competent shop to take a look at the system to try and locate the problem.
The following is a repair shop in Syracuse once you find the component which is bad.
http://***********.com/automotive/
Old 03-15-16, 12:19 PM
StephanieS
StephanieS's Avatar
My 2004 RX330 Radio just stopped working several weeks after the warranty replacement of a cracked dashboard. There is no power going to the radio or cd player. This is a standard radio with am/fm and cd player, nothing fancy. My dealer wants $960 to replace. Says the radio just quit. Out of all of the cars I have owned for the past 30+ years I have never had a radio just stop working. Has anyone had a problem like this?
joeual (03-30-17)
Old 03-30-17, 08:55 PM
joeual
joeual's Avatar
Thumbs up I'm not alone Lexus, first time ever disappointed
Same thing happened to me. Took it in because it was a warranty replacement and it came back with the left front speakers and door is not working we didn't notice it for about a month because when my wife is in the car she likes to talk so the radio is off all the time then came the moment I was driving by myself that I noticed it. I believe they had a rookie because the top of the speaker was not properly aligned and missing a side screw.
Old 03-31-17, 04:20 AM
05RX330AWD
05RX330AWD's Avatar
Normally if a electronic issue is intermittent, the problem should be a contact/ connection somewhere.
I imagine it will not be a very expensive repair if done with a reputable/ honest outfit.
Old 03-31-17, 11:39 PM
viffer
viffer's Avatar
Did you check the rear of the head unit to see if the connection is still secure? There are three wiring harnesses and two antennas. I just upgraded my 04 RX330 (with Nav) stereo with a Pioneer 4200NEX for approx $575 including the necessary wiring harnesses. My new aftermarket stereo has way more features than the stock replacement head unit at almost half the price.
Old 04-03-17, 11:13 AM
harkirath
harkirath's Avatar
Did you do it yourself or get the work done at some shop? Might be looking into doing something similar.
Old 04-03-17, 12:11 PM
viffer
viffer's Avatar
After hours of research on this and other forums, I did the stereo install myself. I made a step by step video of the install, here's the video if you'd like to check it out:
maoslarx33 (01-01-22)
Old 04-03-17, 02:47 PM
PWR
PWR's Avatar
Default RX 330 Radio
I am the one who originally posted the problem with the radio.
I bought a used amplifier (located under the rear passenger side seat) and it has been working for several years.
Old 04-03-17, 04:43 PM
05RX330AWD
05RX330AWD's Avatar
Apparently you haven't read these posts carefully, I responded to your original post.....
again, Normally if a electronic issue is intermittent (otherwise your Stereo works at times, then it doesn't work at times) the problem should be a contact or connection somewhere.
EMILMATCH
07-14-17 08:03 PM
MjThind
RX - 3rd Gen (2010-2015)
52
04-04-13 11:14 PM
Gsnuggs
09-16-12 12:07 PM
georg777
08-01-09 11:50 PM
rcodey
04-28-05 01:59 PM
Quick Reply: 04 RX 330 Radio Not Working
