04 RX 330 65 K mi. Coolant level issue
Old 12-23-12, 09:47 AM
Lexusrxsc
Lexusrxsc's Avatar
Question 04 RX 330 65 K mi. Coolant level issue
Had my RX minor serviced by Lexus dealer who advised that coolant level was low. (Didn't advise how low). Stated that Lexus is beginning to find that low coolant levels could possibly mean faulty water pump.Recommended water pump replacement and timing belt be replaced at the same time. No apparent leaks on clean garage floor. Car treated and driven gently. Anyone else aware of this issue?:
Old 12-23-12, 11:36 AM
carguy07
carguy07's Avatar
Good lord what terrible self serving advice! These cars are known to consume/lose a small amount of coolant over time. Since the dealer has no idea if it was recently full or even if there is a leak somewhere else, I would call BS on the recommendation. Top it off, keep an eye on it. If it loses anything significant quickly, then troubleshoot the leak. If you are due for a timing belt and water pump, then by all means have it done. Otherwise they are just creating work for themselves.
Old 12-23-12, 11:59 PM
salimshah
salimshah's Avatar
^ +1 Excellent advice.
Salim
Old 12-24-12, 05:16 PM
kiwi
kiwi's Avatar
i had my timing belt done on my 2004 about 2 years ago, the dealer recommended that the mechanic inspect it once everything is off, and go from there. as it turned out, my water pump was fine, no need to replace.
Old 12-24-12, 06:35 PM
JoeInHNL
JoeInHNL's Avatar
I had a slow leak (couple of ounces every six months). It was caused by this leak near the lower radiator hose.
PITA replacing the radiator on these cars. The AC condenser needs to be disconnected since it needs to come out with the radiator. They are bolted together top and bottom by some sheet metal clamps.
The coolant and radiator were very clean after 9.5 years.
Attached Thumbnails 04 RX 330 65 K mi. Coolant level issue-coolant-leak-closeup.jpg
CEO714
08-14-14 06:11 AM
toyo
02-23-14 09:51 PM
kee0419
10-24-12 05:27 AM
tdandkd
RX - 1st Gen (1999-2003)
06-21-12 10:15 PM
ta1972
11-06-07 10:25 AM
Quick Reply: 04 RX 330 65 K mi. Coolant level issue
