Slight alternator whine through speakers after new deck
Old 11-12-12, 07:27 AM
mrmonster
mrmonster's Avatar
Default Slight alternator whine through speakers after new deck
Has anyone experienced alternator whine after installation of aftermarket deck?
I started getting a very slight whine, small but noticeable to me. The weird thing is it wasn't there at the very start but came couple months after I installed the deck. Not sure if it's a coincidence but it started the first time I towed something with my new hitch. OEM hitch/wiring. Yes, weird.
I used a Pac TATO harness adapter with a Kenwood DNX7190 headunit.
Ideas?
Old 11-12-12, 08:23 AM
pauljcl
pauljcl's Avatar
Ideas?
In older cars, this used to be resolved by using a condenser on the power line of the radio.
Old 11-12-12, 09:31 AM
mrmonster
mrmonster's Avatar
Normally alternator whine is caused by ground loops when adding amps to the setup and having grounds in the trunk or something. I have no extra amps.
My only idea is to maybe ground the PAC TATO directly to the chassis instead of stock harness ground wire.
Old 11-12-12, 05:36 PM
mandyfig
mandyfig's Avatar
Need to check grounds. More ground the better.
Old 11-12-12, 06:29 PM
HtownBlue
HtownBlue's Avatar
If ypou can run a larger gauge wire DIRECTLY from your Deck to the Frame this will help. Also, you can also check the stock amp and use a larger gauge wire for a ground which allows a greater current flow to ground.
The closer you are to grounding to the frame or sub frame, the better. Grounding to sheet metal often times cannot support the ground current load efficiently, this the feedback.
Old 11-15-12, 08:31 AM
LEXRX04
LEXRX04's Avatar
they are all correct...this is caused by a "bad" ground...you can change the ground to a different ground...if this doesn't change anything you need to check the headunit...there are times where the headunit itself can have bad ground joints internally
Old 12-04-12, 10:29 AM
LexXxtacy
LexXxtacy's Avatar
9/10 when you tried everything, and problem still exist you have to ground the rca going to the headunit. take a while and stick it in the inside of the rca and plug it into your headunit, then ground it
TurbodVq35
05-28-22 11:50 AM
ntwrkguy1
07-31-13 02:22 PM
1uzfe4147
SC- 1st Gen (1992-2000)
02-09-11 12:19 AM
vboy720
16
05-04-09 10:41 AM
sc3boost
Performance & Maintenance
12-21-06 11:42 PM
Quick Reply: Slight alternator whine through speakers after new deck
