Re-Upholster dashboard
Old 08-31-12, 10:04 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
I would file a complain with the corp. office and see how they react....good luck and keep us posted....
Old 09-02-12, 09:19 PM
RuninRoach
RuninRoach's Avatar
Default thanks..
Thanks all....went to junkyard over the weekend unfortunately language barrier hit hard and wasn't able to fully source a solution.
Does anyone know if the Dashboard part number for a 2003-->2009 Lexus is the same if you have a mark levinson audio option?
I tried to look in Sewell but my navigation skills for that website might have let me down. Are they any other good websites i can source this information from? I would google it but i trust users on this forum more than random google results.
Old 09-02-12, 09:32 PM
RX330inFL
RX330inFL's Avatar
You are also probably looking for a righthand drive version as well??? If so, you might have better luck working with someone in Australia to get a part number for you. Sewell isn't going to have the part numbers you need.
Old 09-05-12, 12:35 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
Sewell's site might not help you to find the right part # cos your car is right hand drive......
Old 09-05-12, 03:51 PM
Carver
Carver's Avatar
I have one crack on my dash located at the corner of the AC vent. I's about 6 mm long. I had been told to put superglue iin the crack to prevent it from getting larger and so far it has worked. It's been over a year now.
It was stressed the glue must go into the very end of the crack as it actually melts the plastic creating a new non-cracked surface. The SG I used had a pin in the cap which allowed me to get the glue into the crack quite easily.
Harold57
03-04-17 11:00 AM
PeterMAX
08-15-14 08:59 AM
hypervish
RX - 1st Gen (1999-2003)
22
02-11-12 05:00 AM
RuninRoach
10-15-11 11:25 PM
Static911
12
01-02-03 04:41 PM
Quick Reply: Re-Upholster dashboard
