2006 RX 330 Brakes ?
Old 06-15-12, 10:45 AM
relax221
relax221's Avatar
Default 2006 RX 330 Brakes ?
How many miles before i have to change the brakes ? Presently at 50,000
Old 06-15-12, 11:54 AM
alchemist
alchemist's Avatar
Do you know how to check them? I would say around 60k for the front depending how you drive, rearsca bit longer.
Old 06-15-12, 01:11 PM
Adamjeeps
Adamjeeps's Avatar
If they are original you are most likely very close. Only way to know for sure is measure pad thickness.
Old 06-15-12, 01:55 PM
mandyfig
mandyfig's Avatar
Pad thickness should not be less than 2 mm (0.08 inch).
Old 06-18-12, 09:36 PM
andresatp
andresatp's Avatar
If he is asking when to change the brakes, he probably will not know how to measure the pad thickness........ don't you think? fwiw
Old 06-19-12, 04:32 AM
jfelbab
jfelbab's Avatar
Pads don't get replaced based on some mileage number. They are replaced when they are less than 2mm remaining. Your dealer or service tech should be able to measure them for you.
newb123
Suspension and Brakes
12
07-02-17 05:02 PM
newb123
05-14-17 10:36 AM
dunnojack
05-27-14 02:11 PM
benzo555
08-26-08 11:37 AM
pup
01-23-05 09:31 AM
Quick Reply: 2006 RX 330 Brakes ?
