2005 Rear Axle Assembly
Old 04-07-12, 07:14 PM
Stickeroo
Stickeroo's Avatar
Angry 2005 Rear Axle Assembly
Well, its about that time in her life when she needs some serious parts replacement. While doing the rear wheel hubs I noticed that the Driver Side Rear Axle Assembly was quite worn as well. I can't seem to find a reasonably priced part anywhere online. I'm not looking to spend 500 dollars on an OEM part, I'm fine with a cheapy. I see the Front Axle Assemblies all over for as little as 70 dollars. But no rear ones to be found. If anyone has any idea please clue me in?!
Old 04-07-12, 11:00 PM
Carver
Carver's Avatar
Are you referring to AWD? Here's some FWD rears that are cheap.
http://www.ebay.com/sch/i.html?_mghc...p3286.c0.m1408
Old 04-07-12, 11:36 PM
RX330inFL
RX330inFL's Avatar
Carver, actually all but the last one are for AWD. Am curious to know what the difference is between the two Centric listings. The seller does not make that clear. Would give me some pause before dealing with this vendor.
Old 04-11-12, 04:17 AM
Stickeroo
Stickeroo's Avatar
Default I think you misunderstood me...
What I'm looking for is not the wheel hub assy, but instead the axle itself. On AWD models in the rear, the part that comes out of the differential, and connects to the wheel hub via the axle carrier. This is the part that the wheel hub slides onto. One of the boots was damaged and the salt and water got to the joint over time.
Looks like that (sorta) but I need it for the rear driver side of a 2005 RX330, I have found OEM ones, but they're like 500-700 bucks. Looking for a cheapie!!
Old 04-11-12, 07:21 AM
RX330inFL
RX330inFL's Avatar
Rear Drive Shaft Assembly...
http://lexus.sewellparts.com/oem-cat...X330-2004.html
Best you are going to do is to find a used one pulled off a wreck. Continue to check eBay or to check your local parts recycler, such as:
greedyeee
Suspension and Brakes
03-23-21 08:05 PM
ReLexin
08-29-19 10:31 AM
fantic
GX - 1st Gen (2004-2009)
10-20-15 01:07 PM
perhansa
06-08-15 10:05 AM
jim7485
05-22-15 12:43 AM
Quick Reply: 2005 Rear Axle Assembly
