Radiator Warranty Run Around
Old 12-30-13, 03:35 PM
dandg
dandg's Avatar
Well,
here we go again ! Looks like our needs yet another radiator ! This will be the 4th one that has gone in out 04 RX 330 with 127000 miles.This one I will have to pay for thou,last two were covered (one at 43k the other at 87k).
No more Lexus/TM Radiators for me.Never heard of such poor quality rads.
Old 08-16-23, 01:14 AM
Mkot9
Mkot9's Avatar
Default Yup, radiators
Originally Posted by tfischer
I have an '04 and had my radiator replaced after a leak was found. My understanding is that Lexus got a batch of bad radiators with some bad welds, and that some of these would develop leaks prematurely (a well made radiator will last 10 or 20 years without springing a leak). The problem was not widespread, so a general recall was not needed. Rather, when a leaking radiator in a car in the designated group that received or probably received one from this bad batch, Lexus will replace it at no charge to the customer (this charge probably being born by the supplier of the part, rather than by Lexus). If your car is in this range, then your warranty or extended warranty or CPO warranty is not relevant.
I hope that this information helps (I also hope that it is accurate).
I have an 05 RX330. and definitely had radiator problems. I heard from several reliable sources that Lexus of that period are known for that.
I replaced it myself. It wasn't difficult, just a pain in the butt.
I hope you get your warranty, mine was way past having in. Good luck!
Why are there lines through my text? Huh.....
Old 08-21-23, 06:39 PM
swanscn
7th Gear
swanscn's Avatar
Default it has been 11 years since I updated this thread
And I never provided the details of what actually ended up happening. The radiator in question had the weld problem, they had seam failures. At first Lexus was offering nothing until I pointed out the Service Bulletin after a bit of back and fort they offered free part pay for installation. Since they were also doing the water pump they had let slip that they would be taking the rad out anyway. When I heard this, I questioned why would I need to pay for the Rad since they were already removing and then putting back the rad?
I called my mechanic asked for the best Rad money could buy and the replacement RAD and Labor were less thant the dealer wanted for Labor only. THey tried to tell me I was getting a good deal since I would be getting a genuine Lexus part. My response was that we already determined that the Lexus part sucked.
They replaced the water pump but the filed Rad back in filled it with water and I took it to mechanic and got it replaced that same day.
Moral of the story I saved hundreds of dollars, got a superior part and the dealer never saw that vehicle again. BTW, I still have that 2005 RX330 Thunder Cloud edition to this day. Thinking of getting rid of it since it is not used much only has 89,000 miles.
Old 08-23-23, 05:42 PM
Felix
Felix's Avatar
Sometimes there are aftermarket parts that are improved/upgraded over the oem parts....
shikbas
06-21-12 11:07 AM
ti86la
12-06-10 03:26 PM
cmc5dc
GX - 1st Gen (2004-2009)
05-31-10 09:41 PM
Kostyan
02-25-08 04:48 PM
jfelbab
01-26-06 04:49 PM
Quick Reply: Radiator Warranty Run Around
