Brake Pads and rotor help...
Old 02-15-12, 07:03 AM
rockinx
rockinx's Avatar
Default Brake Pads and rotor help...
2006 Rx400h
my brake pads are under the 3mm mark.. and absolutly refusing taking it to lexus for new breaks..
Can anyone recommend break pads and rotors, i drive alot of highway with an average speed of 65 to 80mph...
Really dont mind spending the extra money on quality break pads, and rotors that wont rust and look orange the day after their installed.
thanks for the help
Old 02-15-12, 07:15 AM
thomas1
thomas1's Avatar
there are a lot of aftermarket rotors.....some come with the painted hubs. As for pads Akebono pads are really good and are generally same as OEM or better. Brembo disks are fine also...I have used them in the past....on my RX300
Old 02-15-12, 10:49 AM
mandyfig
mandyfig's Avatar
Get OEM's Toyota, you will not regret it. Sewell gives us a discount anayway.
Old 02-15-12, 11:59 AM
salimshah
salimshah's Avatar
Originally Posted by rockinx
2006 Rx400h
thanks for the help
The OEMs will show rust spots.
Salim
Old 02-15-12, 12:30 PM
mowmow
mowmow's Avatar
I vaguely remember there was a vendor on the forum selling slotted and dimple dye rotors at a really good price.
Old 02-15-12, 12:43 PM
RX330inFL
RX330inFL's Avatar
Like many topics here, this one has been discussed at length previous. One just needs to search. Of course, you will need to have spelled brake correctly to get the proper results.
The following URL for a previous discussion lists two companies which sell rotors that have special coatings to limit rust.
https://www.clublexus.com/forums/rx-...o-replace.html
Old 02-15-12, 03:42 PM
diverchris
diverchris's Avatar
Still a big fan of KVR rotors. They also have ceramic pads as well
Old 02-17-12, 08:49 PM
JohnLX300
JohnLX300's Avatar
Big fan of Centric Rotors and Akebono brake pads, they were great when I had my RX300!
Old 02-18-12, 09:56 PM
RandomTech
RandomTech's Avatar
A Lexus tech doing this for you mich save you some hassle if the calipers have issues, however unlikely. Replacing hydraulic brake components/a caliper on the 400h requires a Techstream or a scan tool that can disable the EBD and zero down the accumulator pressure (to do the job the right way).
Old 02-24-12, 01:04 AM
mowmow
mowmow's Avatar
hey While, how would you know about the vendor back in 2009 when you've only have join the forum this month.
why on earth did you just copy and paste my sentence ?_?
Old 03-07-13, 04:12 AM
colinshots
colinshots's Avatar
Default RX400H brake pad replacement
I have a 2006 RX400H and the front and rear pads need replaced soon (and possibly new rotors to really do the job well) and as far as I can see it's pretty straight forward but then I read online AND ABOVE that the car will require a reset using a Lexus scan tool when the pistons are pushed in to allow the new pads to be fitted.
Is this true?
I see no electronic wires/sensors on the calipers but maybe it's a fluid level thing.
If it is true then would a commercially available electronic scan tool be able to do this?
Regards.
Old 03-07-13, 07:09 AM
thomas1
thomas1's Avatar
I just changed mine without scan tool...However I did not open any bleeder valve...So far no problems...If you have no shutter when braking dont bother changing rotors...mine have 125k miles and are still fantastic. The Hybrid puts less strain on the brakes as electric braking reduces wear.
Old 03-12-13, 05:03 AM
colinshots
colinshots's Avatar
Thanks for the reply.
You mention not opening a bleed nipple- I considered that to avoid changes in fluid levels being detected when the piston is pushed back in that a method would be to clamp up brake fluid hose at the caliper and open bleed nipple then any pushing back in of the piston would expel some fluid. Close nipple and remove clamp resulting in no change of fluid level at reservoir.
Sound logical??
Old 03-12-13, 06:43 AM
thomas1
thomas1's Avatar
Does, but if you push piston back slowly the fluid will just go back in the main resevoir.....I chose that method.
Old 03-12-13, 07:58 AM
mandyfig
mandyfig's Avatar
No need for a scan tool, just follow the advise as above, you are good to go.
Slash300zx
RC F (2015-present)
18
04-04-18 03:25 PM
LexusLadi
04-02-15 11:49 AM
MidnightGS
12-19-10 05:25 AM
LexLS
Maintenance
10-23-03 12:46 PM
tocoolexus
SC- 1st Gen (1992-2000)
11-28-01 08:23 AM
Quick Reply: Brake Pads and rotor help...
